We picked up a bunch of fasteners today.
Unfortunately the local OSH only had 3 of the LPF-2625U. I got those 3 and some others. The others didn’t work. We went to another OSH and picked up 5 more, enough for two sets. (We needed a few other house-fixing supplies anyhow, so it wasn’t a huge hassle. Plus we got to take the model 3 out.)
I ended up useing some flat rubber washers with the fasteners. A bit large but they almost cover up the delivery scratches.
Pic is attached.
I also bought some #8 stainless “slotted hex” machine screws. These seem to fit better than OEM but I’d like to add a fender washer of an appropriate size.
Another oddity I discovered : the holes in the trunk barely line up with the plate holes (and also the plate trim.). With the larger OEM screws the fit was (I felt) not possible as they were wider.
It looks pretty go now (I think it is straight/level), and it seems solidly attached.
Hopefully a branch reflection. Seriously though, scratches are why I decided to fix the grommet myself. If you do take it to the center, leave the paper tag on it so they don’t let a metal plate or frame scratch the paint.
I also experienced two of the push-in nylon nuts spinning freely in their holes I opted for a more permanent solution and drilled out the square holes and installed ¼-20 aluminum Nutserts®.My rear license plate screw is stripped. I got my plate and tried to unscrew the plate frame but two of the 4 screws just turn non stop.
I can confirm that Tesla's mounting holes do not align perfectly with California license plates, but a few strokes of a round-file in the holes on the plate easily fixes that. I used stainless steel tamper resistant screws to secure the license plates.
-Mark
I used AVK A-T Series inserts and an AVK hand tool. There was some very minor distortion of the sheet metal as can be seen in the close-up photo above (the upper left is the worst of the 4). Here's a shot that shows all 4 inserts...Any problem with distorting the trunk sheet metal?
In fixing mine, a Tesla employee said the problem is indeed delivery-center people using power screwdrivers to attach license plates, and way overtorquing the screws.
From my invoice, the OEM part info for the nuts is:
GROM, SCR, M5 SELF TAP, 0.8-2.5, 7MM SQ (1003209-00-A)
The service people pulled out the old rounded-off nuts with long needle-nose pliers, being very careful not to scratch the paint when gripping the nut face.
Had my grommets strip out as well...waiting for mobile service to fix. Had a buddy who just took delivery and they are now adding a different mounting plate to the trunk, the license plate then mounts to the mounting plate. Wondering if I can get the mobile service guy to mount this instead of the grommets alone.
Ask the Mobile guy to order one and then post the part number for the rest of us, por favor.
....they are now adding a different mounting plate to the trunk, the license plate then mounts to the mounting plate...
