Microsoft? Yeah...that'll be a no. Experienced their "UI" in a Ford Explorer where, yes it was updatable, but you had to figure out whether the update actually applied to your vehicle, had to validate it through a secondary program before initiating, had to have it on a USB in the right file format and it usually took 30 minutes with the car running to complete. The only thing worse was that in order to do a reset of the car you had to pull the fuse. Good luck with that! You needed to be a contortionist. The fuse box was placed directly under the steering wheel but far underneath on the top side, with a small access panel that needed to be unscrewed first, the fuse panel itself buried too deeply to reach the friggin fuse. Usually needed to do the reset about monthly because of glitches. Absolutely hated that vehicle by the time I got rid of it.
