Picked up my S Plaid 6 weeks ago. Noticed from pretty much day 1 a vibration at roughly the speeds described here. I feel it primarily in the accelerator but also slightly in the Yoke. It seems like it is just when I first set off in the morning as I fairly gently (at least as far as Plaid metrics are concerned) accelerate up starting in the mid 30's up into the low 40's. The vibration is more like gear sprockets rubbing or bearings rubbing than out of balance. Or maybe a catch/release sensation of moving past a series of magnets. The vibration has "soft edges" if you will, not click click click .. . It is a rapid vibration that would have a waveform that is more sine like than spiked and is at maybe 30 Hz or maybe a bit higher. It is easily felt by me, I have not had passengers notice, but don't often have passengers. It is not severe and I don't hear anything, just feel it. Is this the same thing others are experiencing? The car is stock and I have it set to Sport Handling and Plaid acceleration. I haven't tried changing those settings.
Thanks for comments and look forward to joining the community. FYI, they also delivered my car with no floor matts and no trunk cover deck. It had the goo on the window, a broken driver side map light and a handle that retracted too deep. Also, the center console where the letters PRND are supposed to be hidden when not lit could be partially seen, just half of each of the last two letters. Fixed all that stuff, have not asked about the vibration. It would be hard to demonstrate since it is intermittent.
