I have tried to find the answer to this question all over, and I can't quite figure it out, so I apologize if this has been answered before...
I live at the top of a fairly steep hill that is about 1000 feet above sea level. I pretty much lose the entire 1000 feet over the first mile of my commute. If I set a charging limit of 90% and leave that limit constant, will the regnerative braking system exceed that limit as I begin what is essentially an almost entirely downhill trip to work (assuming I start out with a full charge to 90%)? It is only a minimal amount of excess charge, likely.
I know the regenerative system disengages when the battery is fully charged (or does it just dump the excess electricty into a resistor?), so I'm wondering if the same thing would happen if a charge limit is set and the energy supplied by the regenerative braking system would result in a charge above that set limit...
