That's the fundamental question. I thought the answer was that both cars were very similar, that the car "runs" off the 12v battery when it's asleep, and recharges it as needed. Several of the posts in this thread say that's correct. My car, however, seems different.So, I guess the charging behavior is different than on the Model S? I remember reading that the 12V battery charging on the Model S kicks in at some minimum voltage and then stops at some maximum voltage, and that voltage cycling repeats 4-5 times per day. Does the 12V battery not drain and recharge as often on the Roadster?
I'm going to an event at the Rocklin SC tomorrow. If I can gently corner a Roadster tech, I'll ask.
