On the lithiums, I found
this on Amazon. It's less than 1/3 the weight (2lbs) of the standard battery (almost 7lbs), but there are a bunch of caveats printed right on the battery. Here's a couple concerning items:
1) Charging voltage must be between 14 and 15 volts. Less than 14 volts and you don't get a full charge, more than 15 volts damages the battery.
2) The Wh rating is 60, so it's only 5 amp-hours. That's less than the 8Ah of the OEM battery.
I don't know enough to have confidence in these lithium replacements.
BTW, the "Needs no maintenance for 1 year" refers to the battery's ability to hold a charge. For stand-by applications, you can charge the battery and let it sit for up to one year before its internal self-discharging has drained it completely.
I found
this battery that supposedly meets OEM specs for $30, free shipping. It weighs 6.72 lbs. There's a also this 9Ah
gel version, which weighs 8.37lbs and costs $10 more. Looks like weight is proportional to Amp-hour capacity. Searching on Amazon for "YTX9-BS" brings up a big list of alternatives, but there really seem to be only these variants:
1) 8Ah with acid you fill.
2) 8Ah ships complete.
3) 9Ah ships complete.
4) Lithium batteries.
The YUASA YTX9-BS battery specs are here:
YTX9-BS - Yuasa Battery, Inc. (6.6 lbs, 8Ah, made is US). Ships dry with acid separate. Yick.
The Interstate equivalent weighs 7.51 lbs at 8Ah:
Interstate Batteries | FAYTX9 , and costs 3X the price. It ships complete with no acid handling required. Interstate batteries have a good reputation - I don't know if that's still deserved or not. Since it's heavier, it might be under-rated (a good thing).
I'm probably going to order the Gruber later today. Seems worth the extra money to potentially not have to replace it as often (12Ahours). I think that a high amp-hour rating should not affect anything in terms of the car charging system.
