wiztecy
1.5 battery is different from the 2.0/2.5.
It was my impression the only difference between the two packs is that the 1.5 uses sheets 1&2 for the 12volt aux. system, and part of those components are enclosed in the ESS, whereas the 2.x has the separate 12v battery / motorcycle battery that's under the passenger front fender. Otherwise the ESS and sheets are identical.
And I believe the PEMs are pretty different and would presumably require a different set of modifications.
Only mods they should need to do is basically an update to the PEMs firmware to accept the new parameters and data bounds of the new ESS. However Tesla in their wording uses the word "upgrade" as if they're changing components. Its vague to say the least if that's referring to the firmware update or not.
