It's hard to clean the touchscreen. When I wipe it with a cleaning cloth it keeps registering as random presses (even if the car is off). It would be nice if there was a "cleaning mode" that would ignore touchscreen presses for 60 seconds.
I suggest people also send these requests into their customer advocate. Here is what I sent to mine:
I have an enhancement / feature request for the roadster.
I am 5'11" tall, and the visibility of the roadster dashboard display is as per the attached photograph. The top third of the speedometer is really not visible at all - as it is obscured by the steering wheel.
The little orange LCD display in the dashboard is very clear, but really doesn't show much useful info. The amps used is ok, but the battery state, mileage and trip odometer are all visible on the color VDS down by my knee.
It would be much better if the roadster had an option to show speed in that little orange LCD. Either just speed, or a setting toggle like the odometer/trip counter switch. Or, simply remove the battery display and show speed there instead.
I am not sure if others have requested this or not, but almost all the owners I talk to complain about not being able to see the speedometer.
Other than that, the car is a dream.
Every change in firmware is an invitation for new problems. I've seen software companies who are 'responsive' to customer ideas, but they also end up with just as many patch releases to fix new bugs introduced during the feature changes. Sometimes it's better to just leave a new feature unrealized. If only a couple of Roadster owners are unhappy with the three existing speed indicators (needle on dash, number in VDS, number in Infotainment GPS) then it might not make sense to go through testing for all of the potential bugs just to add a 4th speed indicator.I can't believe this would be something hard to do but maybe it is.
Good point. If the speed in the Infotainment system could be displayed in the upper right hand corner at all times, I'd be fine with that. That's more of an Alpine issue though so Tesla can't fix that. I just have to move my knee and take my eyes off of the road to see the VDS or duck my head down to see the dash currently. Hopefully it's something they can do at some point.Every change in firmware is an invitation for new problems. I've seen software companies who are 'responsive' to customer ideas, but they also end up with just as many patch releases to fix new bugs introduced during the feature changes. Sometimes it's better to just leave a new feature unrealized. If only a couple of Roadster owners are unhappy with the three existing speed indicators (needle on dash, number in VDS, number in Infotainment GPS) then it might not make sense to go through testing for all of the potential bugs just to add a 4th speed indicator.
... the three existing speed indicators (needle on dash, number in VDS, number in Infotainment GPS) then it might not make sense to go through testing for all of the potential bugs just to add a 4th speed indicator.
As I said, my left knee VDS is behind the steering wheel.
... Demos are much more impressive without the lurch of the regen when I take my foot off the accelerator.
Try hitting the brake very aggressivly (not slam). It slows you down and wows them on good the brakes are.
Wouldn't that make it worse? Unless you're two-footing it you'll get the regen when you take your foot of the accelerator, then the hit from the brakes (admittedly, impressive).....
not to mention the problem of the built-in lag of the needle tachometer making it hard to measure actual speed.
