Roof won't open.
Discussion in 'Model S: User Interface' started by SkyKidFalken, Mar 14, 2013.
  1. SkyKidFalken
    SkyKidFalken TSLA Fanboy
    Vancouver, Canada
    Hello
    My sunroof is not opening since day one. On the pick-up day, I was told to wait for an update to fix some software issues, including the sunroof.
    It's been 3 months and I've had 3 patches, but the sunroof is still not opening.
    I live in Vancouver. It's very rainy down here so I don't mind keeping the sunroof closed all day.
    Maybe it's not a software issue.
    Anyone had the same problem?
  2. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Get to a service center and get it fixed .... clearly not a software issue at this point...
  3. Bifff67
    Bifff67 Member
    Northern Virginia
    Happened to me, suspiciously right after 4.2 download. Worked for months before that. I have not taken time to ask about it yet.
  4. dtich
    dtich #P708
    Los Angeles
    most likely just needs to be recalibrated, takes a minute.
  5. SkyKidFalken
    Vancouver, Canada
    Tried to contact the service center in Vancouver. No one answers my call.
    I've had bad experience with some of the employees here in Vancouver. They agreed to fix the scratches on my car on the pick-up day but later refused to do so.
  6. mnx
    mnx 2013 P85
    Ancaster, Canada
    I think if you let it ring long enough you call will be forwarded to HQ. At least then there will be a record of your problem in their system.
  7. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    That sounds like bad customer service. Did you have the scratches noted as a due bill repair at delivery? Have you called Tesla's ownership experience team to escalate your request?
  8. RichA
    RichA Member
    Silicon Valley, CA
    I had this happen with the 4.2 update. Call the service center, they contacted engineering who called me while I waited in my car. They recalibrated over the air and it worked right away. About a 10 minute process. I hope your fix is as simple.
