Route planning for a Supercharger trip through the southwest
Discussion in 'Mountain/Southwest Supercharger locations' started by NeverFollow, Mar 22, 2017.
  1. NeverFollow
    NeverFollow Active Member
    I see, to go for example from Tuscon, AZ to Austin, TX you have to go to the north toward Alburquerque, NM
    Instead of going east, passing by El Paso, TX. Big detour!!!
    So, Tuscon, AZ to the SpC in Albulquerque, NM is about 440 miles.
    And Tuscon, AZ to SpC in Van Hornes, TX is also about 440 miles.
    Only option is going north to SpC in Holbrook, AZ about 240 miles, seems possible with your P85+ 265-mi (EPA)
    Better would get a new SpC in Las Cruces, NM about 275 miles, but might be challenging for a P85+ unless driving slow.
    Really need a new SpC near the states line, like Denimg, NM about 215 miles from Tuscon, AZ
    And then Denimg, NM to Van Hornes is 220 miles. Could works going east even with a 60D, if not using AC...
  2. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Moderator note: the post starting this thread was moved from the Fremont #2 Supercharger thread in the California forum because it was off topic for that thread. Anyone who wishes to discuss that decision, please PM me. Thank you.
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Yes, we've been waiting for I-10 between Arizona and central Texas for a long time. It's on the map for 2017 completion, whether that happens or not we'll see. So far 4 superchargers on this route have opened or are under construction this year. Nothing new here.
  4. BerTX
    BerTX Supporting Member
    Texas/Washington
    There is currently a Supercharger under construction in El Paso. That is just about exactly halfway between Deming and Van Horn.
  5. BerTX
    Texas/Washington
    I try to put this information on route planning for I-10 in as many places as I can. Sorry if it is repetitive.
    Google maps, which most of the trip planners are based on, provides average speed data for each stretch of roadway. Very accurate, crowd-sourced information collected from drivers actually on those roads. HOWEVER, some stretches of road have misleading data -- my theory is that trucks are driving slower and skewing the data.
    The stretch of I-10 between Kerrville and El Paso has an 80 mph speed limit. I would imagine most Tesla owners, once the Supercharger route is finished here, will want to drive at least that fast. Problem is, Google tells the planning applications that the average speed on this road is 74 mph. If the user accepts this speed and charges their car according to this prediction, they likely will come up well short of reaching their next supercharger stop (well, they'll have to slow way down, anyway).
    Check your speed correction in the planners to verify the speed it says you will be traveling on each stretch of this road. The Nav uses this data as well, so leave a significantly higher buffer than you normally would.
  6. jsmay311
    jsmay311 Member
    Chicago suburbs
    The "2017" map on this page: (Supercharger | Tesla) seems to show future plans for stations in/near Raso, Deming, and Las Cruces.
  7. PLUS EV
    PLUS EV Running on Empty
    Seattle
    Tucson to Holbrook supercharger is a no go in just about any Tesla due to elevation gain. Unless of course you use some extreme hypermiling techniques or route through PHX metro and charge along that route.
  8. BerTX
    Texas/Washington
    Raso? Is that even a town? Probably Willcox.
  9. PLUS EV
    Seattle
    I had done that drive a couple times (in an ICE) and couldn't remember Raso either, but IIRC when I zoomed in on the 2017 map, it did indeed look like the dot was on Raso, whatever that is. Hopefully more than just a name on a map :)
  10. jsmay311
    jsmay311 Member
    Chicago suburbs
    You're right. The latest map update shows the future Supercharger location in Willcox.
    It also shows one planned for Deming.
    And the one that looked like it was in Las Cruces was actually El Paso, and that location opened April 20, 2017.
  11. PLUS EV
    Seattle
    Yes, I noticed the new map updated to Willcox instead of Raso, thank goodness. I just looked up Raso on Wikipedia and Google images and couldn't find any evidence of actual civilization, so that would have been a poor choice for a supercharger!
    This reminds me of an old Nevada thread where someone was suggesting they put a supercharger in Deeth, NV, and I was thinking "I've done that drive many times and don't remember Deeth whatsoever." So the first time I did that drive in my Tesla I decided to try to stop at Deeth out of curiosity and I ended up not being able to get there because I reached a gravel road that was impassable due to being covered in water (It was a wet, wet winter, but still). Fortunately the supercharger team did not actually choose Deeth for a location :) Just goes to show that you can't just pick names off a map that are ~100 miles apart to select supercharger locations. Some knowledge of the local amenities is necessary. This is particularly important in extremely rural areas such as SE AZ and NE NV.
