ZachF
The issues is less so one of electricity generation. So the longer term solution for them, like us, is heat pumps.
You do realize heat pumps run on electricity, right?
Recall again the discussion here that "longer term solution" means the correct goal of heat pumps can't be achieved soon enough and that Russian NG imports will be wound down prior to that being achieved in significant part with the aggressive time table in play of German Economy Minister Habeck. Will take a few years just for heat pump deployment to remove low double digit percent NG consumption. Will take a decade of aggressive deployment of heat pumps to get close to where they need to be.You do realize heat pumps run on electricity, right?
Maybe Biden can invoke the defense production act to greatly increase the number of heat pumps manufactured.Recall again the discussion here that "longer term solution" means the correct goal of heat pumps can't be achieved soon enough and that Russian NG imports will be wound down prior to that being achieved in significant part with the aggressive time table in play of German Economy Minister Habeck. Will take a few years just for heat pump deployment to remove low double digit percent NG consumption. Will take a decade of aggressive deployment of heat pumps to get close to where they need to be.
To that, even if that were not so, nuclear does poorly with daily and seasonal demand response. So yes, nuclear is indeed a red herring.
Governments from corners around the world should be seriously looking at this. There are strong national security and climate arguments to be made.Maybe Biden can invoke the defense production act to greatly increase the number of heat pumps manufactured.
Warming to my own theme, if the WW2 (or Serbian, more recently) amateur boffins were in charge, they'd be making loads of inflatable/wooden/dummy tanks, SAM traps for Russian aircraft dropping unguided bombs and spacing out to a huge degree forcing lower altitude air attacks. Having an overabundance of M113s, many uncrewed or just with a driver with no ammo is a feature, not a bug.
Single driver vehicles can be carrying food/water internally with trailers for incendiary material (fuel/ammo). Trailers probably also help with lower ground pressure over dodgy terrain. More targets than Russian airforce can hit safely, more unknown-if-crewed threats for Russian ground forces, more than Russian ammo could destroy. Many M113s with SAM crews to shoot down low altitude aircraft, especially helicopters.
I'm really minded to think of these not as "tanks" (misused term) / fighting vehicles but as updated Bren/Universal carriers, a nearly forgotten key to allied success in WW2. 113,000 (I'm surprised not more) of these were built and they were used post-WW2 as well. With a tow hook, tracked trailer M113s could be carrying infantry weapons of all kinds SAMs (low altitude), anti-tank missiles, mortars, ammo, fuel and everything. Also could tow artillery/rockets.
Universal Carrier - Wikipedia
Older relatives raved about Bren-gun carriers - it took the effort off the infantry and for operations in open terrain, I can imagine that lightly loaded M113s with trailers, corduroy roads could escape much of the worse of the mud come autumn and fulfil a similar role.
Any T72 targeting one of a group of M113s supported by drones, artillery will become a target very quickly. It's rather like in WW2 that Germans learned to avoid firing at allied spotter aircraft as risk/reward not worth it (until someone added bazookas to a spotter).
Use of Universal/Bren Carriers increased over time (from 10 to 33), a sure sign that Bren carriers worked and was wanted, it was just supply-constrained. The constraints on doing something similar NOW are largely money, will with some real, hard constraints of parts, training and essential kit such as optics.
"Universal Carriers were issued to the support companies in infantry rifle battalions for carrying support weapons (initially 10, 21 by 1941, and up to 33 per battalion by 1943). A British armoured division of 1940–41 had 109 carriers; each motor battalion had 44"
"In Motorised Infantry Battalions in BAOR (British Army of the Rhine) in the early 1950s the Universal was issued one per platoon carrying the Platoon Commander, driver, signaller and the 2-inch Mortar group Nos 1 & 2."
The Ukrainians are amateurs (in the best sense, lovers - from French? They have purpose, fire, a mission and can innovate, supported by tech-savvy people and the west), not top-down constrained. I firmly believe if you give them kit of any kind, they'll be inventive.
The other thing that elderly relatives talked about was their use of indirect / plunging machine gun fire (taught even in the 1950s, presumably used in Korea). How much better with computerisation, digital comms, remote weapon stations and heavy machine guns. A bunch of networked, computerised half inch machine guns using plunging fire must be devastating to unprotected troops such as artillery or even entrenched if no top-cover. Mounted on M113s, spread out, converging fire on point or area targets.
According to reddit (must be true then..)
"The maximum effective range for an area target (read: direct fire) for the M2 is 1,830m, but the maximum range for the weapon is 6,764m. Effective plunging fire therefore falls somewhere in between this range, generally around 3000 - 4000m."
I doubt Elon wants to become Tony Stark in his arms dealer days, but this is a bit of robotics, programming and building on existing kit. Add grad rockets, mortars etc. The driving of M113s must be done by people, and targeting can be done by people in M113, on foot, ebikes, drones, satellite/intel while the firing solutions can be computerised.
I have a funny story about procurement of Leopard 1 by the Royal Canadian Armoured Corps. I'm not going to tell it though. I only bring it up because the story dates back to 1978. :/
It's moot anyway, the reactors they shut down years ago can't realistically be restarted in time to matter. But the three they turned off a few months ago probably could, and they could extend the three they (still!!!) plan to shut down in December. That's sheer lunacy which only worsens their Russian gas dependency.Nuclear won't solve the problem because, like us in the States, the majority NG use is seasonal and used for on site combustion/heating in the winter. The issues is less so one of electricity generation. So the longer term solution for them, like us, is heat pumps.
Figure 1: Germany’s gas consumption between January 2020 and August 2021. Source: Energy Projections’ Germany natural gas fundamentals dashboard
One can hope that the procurement for Ukraine's armor reinforcements would follow the Leopard C1 process. As far as peacetime procurements go, it was a model of success, 4 years from requirements to procurement closure. Of course, it better be faster now under wartime circumstances...I have a funny story about procurement of Leopard 1 by the Royal Canadian Armoured Corps. I'm not going to tell it though. I only bring it up because the story dates back to 1978. :/
Bloomberg says that despite our so-called "crippling sanctions" Russia's revenue from oil/gas exports will rise more than 33% this year, to $321 billion. Leaders correctly say we need to cut off that revenue, but they lie about the method. When they say "stop buying Russian oil" they really mean "replace it by outbidding some poor country like India for middle eastern oil". Then they act all outraged when India replaces their lost mid-eastern barrels with Russian oil. It's hypocrisy of the first order.
Russia exports ~7.5m bpd of oil and gasoline/diesel. About 1/3rd of that goes to China, who will not stop buying. And the only way to cut off the other 5m bpd is for the west to reduce net consumption by 5m bpd. And we can only do that with a war-time rationing program.
Rationing by price will not work. First, it's simply unjust to put the burden of a political decision entirely on the poor. Second, oil demand is too inelastic -- the sky-high prices needed to slash consumption that much would benefit Russia more than hurt them. A war-time rationing program like we had in WW2 is the only option. It's probably political suicide, though, so we instead get lies along with lip service about supporting Ukraine.
This was discussed upthread, so not sure why you continually post unsubstantiated Imran propaganda.Even as NATO talks about evils of Russia, US has effected yet another regime change.
That too in a region that has paid a very heavy price because of US - Russia hostilities.
Cable confusionIt later emerged that these ‘revelations’ were in fact claims based on a routine diplomatic cable that had referenced remarks made by a US state representative on the possible outcomes of a vote of no-confidence against Mr Khan and what they could mean for Pakistan. We do know that the language and tone of the communication were such that the National Security Committee termed it “blatant interference” in Pakistan’s internal affairs and recommended sending a strong message through diplomatic channels.
Apart from that, it did not seem there was any imminent threat to Pakistan’s national security. However, going by the self-righteous fury evident in Mr Khan’s recent speeches, one would think it is no longer contestable whether a foreign conspiracy is actually in play or if he has just made a mountain out of a foreign diplomat’s poorly chosen words.
Exactly what does this have to do with Russia's attack on Ukraine? Other than your usual distracting "whataboutism".Even as NATO talks about evils of Russia, US has effected yet another regime change.
Its about Imran's support for Russia and at least partly because he refused to support the Ukraine war.Exactly what does this have to do with Russia's attack on Ukraine? Other than your usual distracting "whataboutism".
I see you ignored the part about how this is all based on his own unsubstantiated propaganda...Its about Imran's support for Russia and at least partly because he refused to support the Ukraine war.
And it is about hypocrisy of a lot of people on this board.
ps : The reason US can interfere so easily in other countries and depose democratically elected leaders is that Americans just don't care.
The US doesn't have clean hands in Iraq and a lot of places, but Pakistan? We knew full well that the Pakistani Intelligence was supporting the Taliban and were giving sanctuary to Bin Laden. Which was why we couldn't tell Pakistan what we were doing when we took out that vile SOB. Every country does what is best for themselves.Its about Imran's support for Russia and at least partly because he refused to support the Ukraine war.
LOL. And you have deep inside knowledge about Pak military ?Um, sorry bud. But you have absolutely no proof US is responsible for Imran’s loss of confidence vote. Imran lost the support of the Pak military last year itself. Please don’t fall for speculative reports out of Pakistan.
Back to the main thread.
Really, you think US had nothing to do with sudden no confidence motion a month after Ukraine war ?The US doesn't have clean hands in Iraq and a lot of places, but Pakistan? We knew full well that the Pakistani Intelligence was supporting the Taliban and were giving sanctuary to Bin Laden. Which was why we couldn't tell Pakistan what we were doing when we took out that vile SOB.
I highly doubt it. Every country does what is best for its ruling class.Every country does what is best for themselves.
