Depends what you mean by rescuing? Any electric car that has been in a heavy accident and potentially damaged the battery needs dealing with very carefully, you can't just drag it up a flat loader and dump it at a local garage. If the battery ignites, almost nothing will put it out, you are pretty much best to let it burn out.... in a controlled manner. If you're worried about getting stuck in a car after an accident, then if it was hard enough to rupture a battery it would more than likely rupture a fuel tank and lines and in a petrol car you've got seconds before the thing goes up in flames rather than minutes with an electric car, so you're much more likely to get out alive.
All electric cars have to have easily accessible and marked high voltage disconnects that the emergency services can use.
I'd have thought that a few years ago the emergency services were still working out how best to deal with EV's, but now it shouldn't be an issue.
