I think there is only really one way to find out. But if its a puncture it will probably be a new tyre. Most places won't fix a puncture that close to the sidewall.Just discovered a screw in the rear offside tyre. Think it’s only just happened as heard a crunching noise on the way home.
It’s gone in at quite an angle so wondering if I’ve got lucky and it’s only in the wall. What do you think?
Oh, that’s not goodI think there is only really one way to find out. But if its a puncture it will probably be a new tyre. Most places won't fix a puncture that close to the sidewall.
I had one replaced at 5k for a similar puncture. and I only bought 1 I think at 2.5K you will be fine on that front.Oh, that’s not good
I haven’t got a plug kit but probably worth getting one before I attempt to take it out I guess?
I’ve only done 2500 miles so hopefully I can get away with just changing the one tyre if it’s needs doing.
Where’s the best place to get a matching Hankook fitted?
If you find a friendly local place they could be willing to patch that if necessary. I've had tyres on other cars that were close calls which dealers insisted could not be patched but our friendly local place were happy to fix. Yours from the photo looks probably too close to the edge to patch if the screw is long and did penetrate the carcass but it's worth asking some place you trust.Oh, that’s not good
My local garage is black circles premiere. When I was there once a black circles delivery came in and I got chatting to the delivery driver.I got mine from a local garage because they could do next day but Black Circles would have been 15% cheaper if I could have waited 2 days but I needed it sorting ASAP.
I’ll go and get a plug kit tomorrow and then pull the screw out. If it is punctured I’ll run it to the local on Monday and see what they think.
Very lucky!Phoned up a local fitter who said to spray soapy water on the tyre and slowly undo the screw. If bubbles indicate a leak then screw it back in and bring the car in.
Luckily it was only half a screw and there were no bubbles. Tyre pressure has remained constant.
The matching Hankook tyre with T1 rating would have been £290 so glad I didn’t have to replace it…. this time at least!
