apologies for another rookie question... if there is a BPS that is currently at max loss, do you even bother buying them out? i am trying to understand how that works
for ex, you STO 300/400 for $2 credit
to BTC it now would cost $5 debit
assume you don't have capital to increase width and/or improve to lower strike so it is beyond rescue, do you
- wait for the 400 assignment and deal with it when that happens
- do nothing - wait for MM to take the whole thing at expiration
- BTC the whole thing - under what circumstances would you do this? and why? this is my main question - why would one even bother to BTC it at $5? what is to be gained?
really would appreciate any answer to this, TIA!
The made up example isn't a good one for understanding a somewhat typical circumstance.
A better way to look at it is, as
@Chenkers put it, is that position is worth $99 (rounding). On a $100 wide spread you've got a 99% loss. But the entry was probably worth a $4 (4% of spread width) credit, so you're actually only at a 95% loss with 1 more point available to lose (at expiration when time value reaches 0).
You would buy this loss out in order to save that final 1% and avoid the thrash and incremental loss available on the 400 strike put assignment followed by your own sale / exercise of the 300 strike put. B/A spreads being what they are, you could easily add several extra $ of loss, and turn a $95 net loss into a $105 net loss (on the $100 wide spread).
If you're close enough to expiration you could roll that spread out in time, and probably to worse strikes, for a small debit or credit. The worse strikes though means that you'll have to wait longer for a good close to show up, as well as having a short leg that is that much more susceptible to early assignment.
Basically - as long as the short leg isn't in danger of early assignment you'll be able to hold your max loss (little opportunity to lose further) to expiration (and assuming the spreads are cash backed, not margin backed). Margin or early assignment are the triggers that shortens your shot clock.
If you're looking for a share price move of that magnitude a credit put spread is a bad way to make use of the move.
Also in the particular example you might find that you can roll that 300/400 put spread to something more like 200/300 and a small debit. The loss is still nearly max loss on the 200/300 and you only need to pay the different in the 2 max losses. Sadly the likelihood of early assignment continues to haunt you with that $300 put strike, but at least recovery is a lot easier and faster at the 300 strike than the 400.
A more personal example that I'm in and that I think is more representative of BPS grief - I had 170/155 put spreads that I rolled into 170/150 for a small credit. Total credit about $2. Then rolled out to Jan '25 175/150s for about a $2 debit. The $15 wide spread (and $15 max loss) has now opened up to $25 and is currently worth about $18, with roughly $0 net credit on the position. So I've managed a 120% realized loss so far on the original $15 wide spread, with an opportunity to earn that all back. The difference in the various available rolls wasn't much different between a week or month roll and the 2 year roll - I feel very comfortable about the 2 year roll eventually recovering that, current, $18/share loss, a feeling that I don't have on any earlier expiration. $18/share or 70% of the $25.
My primary concern about the position is that the share price keeps going down to the point that the 175 strike put time value decays close enough to 0 for early assignment. Early assignment will cause realization of that $25 (maybe $24) loss, where I'm looking for time to heal this wound. My back is up against the wall with this position - nowhere else to go that doesn't involve throwing more cash into the fire without decreasing the max loss; there is little or nothing left that I can do to improve it and avoid the max loss (can't go any further out in time, and if the short put is far enough ITM to have no time value, then there isn't another strike I can go to; this is why spreads behave so very differently from naked puts).
But the current share price of $125 isn't an issue - I'm about $50 ITM on the 175s with an option value of $71. That's about $20 worth of time value and nobody is going to give that to me. Heck - I'd love early assign on these 175s right now - I'd promptly sell the shares and score that $20 worth of time value, as well as be able to sell the long puts for their value, and come out way way ahead on the current position. Like turn a -$18 unrealized position into a $70 realized position (the $20 time value on the short leg, plus $50 current value for the long leg) for a net $88/share gain on a $25 max loss position.
A more likely scenario that one would go through. The reason to buy out the current mess is that I can pay the $18 loss and 'save" the remaining $7 that's on the table and available to be lost (I like my Jan '25 $25 wide spread better). I took the "buy out the loss" choice a year ago when I had a $150 wide spread turn into a $130 valued spread. I bought out the loss in order to save the remaining $20. That was a 333/283 spread. Turns out that rolling it would have spent some money and would involve options being assigned; might have turned that $130 loss into more like $150 or more by now.
The downside to a 2 year spread is that the value of the spread is going to be moving slowly as the share price goes up. The move from 125 to 165 is going to lower the spread value to about $12. That's the midpoint of the spread when time value on both legs is about the same, leaving the spread valued at 1/2 spread width. At a $200 share price, my max dated spreads will probably be worth about $6 - maybe a big enough improvement to be worth buying out at that point (still eating a $6 or 25% loss on the position), but relative to now - "saving" 3x what I can save right now. I'll probably find a different mechanism to closing out / earning that final $6.
Whatever I do my position is 100% dependent on a significant move in the share price back to my spread strikes.
