Heh, the first link in that search is this thread. The Internet is the best.
Anyone have any hints on finding the relevant video after you have a 'sentry mode event'? I'm assuming it's under the SavedClips folder, with each event having it's own sub-folder. Problem is, under each event folder, there are about 30 1-minute video clips. Ain't nobody got time to look through all those. What's the secret?
Since we're concerned about manufacturer specs, might consider that Samsung itself voids the warranty on their EVO and Pro line of SD cards when used in a dashcam application. Caveat emptor! I didn't bother to look up the flash drive, but guessing it's the same for those.
Relevant section below for the Samsung EVO, EVO Plus, EVO Select, PRO, PRO Plus, PRO Select.
Yep, Samsung PRO Endurance 128 GB is working for me also for the past 3 weeks.Just a note for people that Samsung's microSD card Pro Endurance line is rated for dashcam use. I've been using it for a few weeks in my Model 3 now with a card reader. Time will tell.
https://www.samsung.com/semiconductor/global.semi.static/Samsung_Data_sheet_2018_PRO_Endurance.pdf
If you plan on enabling Sentry Mode regularly, you'll need to take out the USB storage device periodically to delete old/extraneous files, lest you run out of space (Sentry Mode recordings do not get overwritten automatically). How often you need to do that is related to the storage capacity of the device.I only plan to take out usb if something happens to my car then look at videi
Well that's dumb
Just started trying out sentry mode.
Left car at airport for only one full day. Had 3 “events” although what it calls an event is suspect to me. Does it actually trigger even if a car drives in front of the forward facing camera? That was about all 8 could see that might have triggered some events.
So let me see if I understand. 3 events = 10 1 minute recordings X 3 cameras for a total of 90 minutes of video?
Dang. That seems like a lot. If I left the car for even a few days with this enabled I could have hours upon hours of video to sift through. Or worse drive is completely full after a couple days?
My original TeslaCam 32GB Drive was fine for dashcam but isn’t gonna cut it for Sentry mode.
Wish there was a another way to remotely check the videos and remove or something.
Do you only come out at night? Do you eat garlic? Can you see your reflection in the mirror?I’ve combed the videos and although it has saved and recent videos I am not on any of them anywhere to be found. Just empty videos of my garage.
How can the cars buffer, that writes to the flash drive miss things?
I have been finding Bat poop in the garage more lately. WeirdDo you only come out at night? Do you eat garlic? Can you see your reflection in the mirror?
What doesn’t help and makes it more confusing to me is when an event is triggered, like you guys say it grabs the last 10, 1 minute clips and saves them to the drive. But it time stamps all of them with the time stamp from the event. Instead of the time each clip was ACTUALLY being recorded.
