Hi There,
Posted bits about this on Facebook (Telsas owners club UK), but not sure about the searchability there and thought I should document for others!
This Message popped up whilst driving Saturday. Service mode gives GTW_W021_thcMia
A facebook user posted "Thermal Controller Missing in Action" - Which appears about right.
The car drives FINE, which is different from any net search. Everything appears pretty normal, plenty of beans etc. However the climate control doesn't push out air. Low/High, the controls work on screen but nada, zip, nothing!
I ran a multi-meter across the frunk fuses (Pulled the fire loop first) and swapped the relays that matched between slots (hoping to loose rear defrost) but everything was the same
Contacted Tesla and 4 days later they're back with an estimate £330, though interestingly that mentions £25 for changing a relay (1011602-00-A 40v, 12volt) and Low voltage Circuitry Integrity check at £165 and a half hour on the climate control - though I believe this is car restriction because of keeping stuff for the Thermal Controller!
Tesla Service Appointment booked for Tuesday. Will see what happens
Lee
Lee
