Good points, thank you. In fact, I just got off the phone with two other electricians/companies to schedule getting more quotes and will DEFINITELY follow your advice! Thanks again!!If the electrician doesn't know that a device requiring a high amperage continuous load can only occupy 80% of the rated capacity of the circuit, they're *NOT* an electrician, they're a fire-starting handyman. This is code, any real electrician is fully aware of this.
Yes, it does. And code in most places still requires a GFCI breaker on a 240v to the garage, which means you end up with nuisance trips due to 2 GFCIs on one circuit. And you pay just as much or more for this setup than you would for a hardwired device.
I disagree with this advice. This is often referred to as "Tesla tax", but in general it's gouging. This is just a circuit ran out to the garage. Two hots and a ground wire, rated for whatever amperage you're targeting (considering that you can only run a continuous load at 80% if that amperage). Your price should be based on the amount of work and materials, not on what you're using it for.
It might take an aggressive approach, but I think you'll get a much better price if you tell them the price. Asking for a quote is an open book. If you tell them you're looking for a 200A service upgrade for around $1,200 and they say no, ask them how close they can get to that price. A straightforward service upgrade is a day of work, maybe $500 in materials.
- Richard
