Show off your aftermarket wheels.
Do you only notice it as it’s parked? While it’s moving, if so for how long before it resets?
Only when parked. It's always a pretty minor difference (1/2" max), but I'm used to coilovers where you can adjust the height down to milimeters and have it stay exactly there.
It seems like it'll adjust the next time it is on a different surface, parked and motionless. You can actually hear the air increase/release if you listen closely.
Not sure how many times you have installed them or even removed all for tires but afterward it will usually make a loud noise as it drops on one end as the car levels out. Afterwards they say to start from Very high and continue to lower to each setting until very low, and than again on the way back up.
If it's the noise I'm thinking of, that's just because it's trying to adjust the height down, which moves suspension components and angles, and you're in park with the brakes on so it can't "flex" as it comes down. If you put it in neutral or drive and let it roll while it's coming down, you shouldn't hear that noise anymore because the components can move as the tires roll.
Honestly, it oculd just be that my garage floor isn't perfectly level, so the suspension *appears* as though it's not leveled when it's in there. I'm not sure. I wish we could get visibility into the pressures for each air shock...that would basically solve all of my questions, because I can't tell if it adjusts each corner separately, or just front/rear axles.
Do you leave it parked in very high? I have actually noticed this only in my P85D+ when it’s parked in very high
Here’s another set of shoes I run on my Tesla. These are custom powder coated Forgiato Maglia’s and are 9 inch Fronts and 10.5 inch Rears I believe. I have so many it’s hard to keep track. I would be willing to part ways with some of the rims at the right price. These are 21’s but look like 22’s and are extremely light. I have had the fastest times ever posted by a P85D and DL with these on my Tesla.
I put these on a black car cuz u never see black cars with white rims. I would still do this look and add accents in white like I started too but the would be amazing on a red, white, or even any color as it has black and white with the red F center caps
My bad I hope no one thinks I was running 21 inch rims on the front and 22’s on the rears lol. Just noticed now. But @duybile this is how they look with being able to run spacers not adapters that would mess up the fitment.
You saw the ag’s above. Using these studs allows you to run up to probably a 15mm spacer or more if needed. Adapters are obviously better the thicker you go but throw off the offset if you have them perfect. Like I said I would use 10-15mm spacers on those ag’s if I install a widebody kit to run it flush with the fender flares.
Lmk if u want to know what studs and the best tool ever invented to install them. Literally took 15 min
Reactions: FlatSix911
Need some advice and help please, I have the option to buy a 20 inch 5x120 vorsteiner v-ff 103 set of my taste but has 8,5 front wheels width. (I have a model S 70D)
Most here I see with 9 or 9,5 fronts. Is 8,5 too small and not recommended?? (Thinking of a staggered set)
8.5" is the factory width of the front turbine/arachnid wheels. I think some people just prefer if going with an aftermarket wheel to go wider but there's really no negative to sticking with a stock width wheel if the desired offset you like works.
If you want rim protection, get 8.5. If you like the stretched look get 9 or 9.5.
Regardless which width you get, you are pretty much stuck with 245 or 255 tires.
2014 Model S P85D
Wimtesetup:
19x8.5 drag DR73 wheels with Michelin Xice. Plasti dipped the window trim and front nosecone too.
View attachment 521485 View attachment 521488
Meant to say winter setup before hitting submit.. Same configuration as the stock 19s squared.
I have the stock dark gray 21 inch staggered turbines if anyone wants them reasonably for $1000 obo. Will put them back on in a month hopefully. MN winter's you never know.
I'll vinyl the rest of the chrome after winter too. Lower it, new aftermarket wheels, front lip done️
