jdcollins5
You are correct, FPWN is 77.8. Without any other reference point, and since SMT was not available when I bought my car, I will just use this as my reference point. Unless you have other reference points to use.Sure. Just out of curiosity - are you sure it is 78.8kWh, not 77.8kWh? That would be interesting but LR RWDs are rare so perhaps it is (I always thought it was the same as the LR AWD (77.8kWh)...but again really very few SMT captures on LR RWD).
In any case, as has been said, Full Pack When New is just a hard-coded value and is not particularly relevant for any metric - though for older vehicles it more closely aligned with the actual NFP when new. For the 2021 LR AWD in particular, it tends to be strongly mismatched (82.1kWh for models later in the year, and NFP starts around 79-80kWh...whereas for the 2021 LR AWD earlier in the model year it was 77.8kWh and started at around 78kWh...and for the Performance 2021 it was always 82.1kWh FPWN and ~80.5kWh-81kWh NFP when new for most vehicles). This FPWN value is discussed in the FAQs on the SMT website.
Definitely FPWN should be ignored when looking at and calculating capacity loss - unless it happens to align with the NFP when the vehicle was new.
In any case, your car likely started around 78kWh (this is based on other vehicles) and that 78kWh includes the buffer (as you can easily see yourself from your SMT captures, by looking at SOC %, nominal remaining, and buffer size, at a variety of SOCs).
You have to use the NFP when your vehicle was new. If you don't know that, you have to piece together evidence from other vehicles of where your vehicle may have started, which at best will be an approximation, as all vehicle packs are slightly different.
My current Nominal Full Pack = 69.6 kWH
So my degradation would be 69.6/77.8 = 0.8946 or 89.46%. Correct? I realize this may not be exact, but close enough for me.
Thanks again for your help.
