No changes to the Model S battery. 100kwh like it has been for ages.
Think what you like, but it’s quite true. Crawl under a brand new Model S and look at the battery sticker for yourself. It says 100kwh plain as day.That, I'm pretty sure is not true. There's no way that the battery capacity has not changed in 4 years.
Read somewhere that a model 3 battery pack is now 82KWh. The LR+ is rated at 288Wh/m and 402 miles, which implies a 115KWh battery. Am I missing something? Is my math wrong?
I think the efficiency numbers they quote are questionable at best. I agree that the math does not work out when you use range, efficiency and battery capacity together.Read somewhere that a model 3 battery pack is now 82KWh. The LR+ is rated at 288Wh/m and 402 miles, which implies a 115KWh battery. Am I missing something? Is my math wrong?
YesThen, efficiency would have to be 250Wh/mile or less
I’m sorry, you’re still wrong.so it sure ain't 100KWh.
Yes
“Starting today, all North American Model S Long Range Plus vehicles have an official EPA-rated range of 402 miles, representing a nearly 20% increase in range when compared to a 2019 Model S 100D with the same battery pack design”
Model S Long Range Plus: Building the First 400-Mile Electric Vehicle
This might also help shed light:
The Adjustment Factor Tesla Uses to Get Its Big EPA Range Numbers
That being said I don't believe that they haven't improved battery capacity in 4 years. It's unlike Tesla
The trouble we have is when we use rated consumption and rated range to calculate usable capacity. So, speaking from "facts," at least the ones Tesla gives us, you find the following (sorry, Model X numbers here - someone can add Model S if they wish):Like I said, look for yourself. Why would the battery sticker lie?
Go look at the online parts catalog - https://epc.tesla.com. Find any battery part numbers with a capacity over 100kwh?
Belief doesn’t play into it. Facts are facts.
Forgive me I haven’t slept in going on 45 hours now. But how can battery density increase but battery size stay the same?same sized battery but additional capacity due to density increase by panasonic.
Model S still has the crappy old style batts (different chemistry), so it won't see the same.
Where do you get the Wh/mile rating from ?The LR+ is rated at 288Wh/m and 402 miles
Chemistry can affect either or both of:But how can battery density increase but battery size stay the same?
Again, because this bears repeating, there is zero evidence that current packs have altered chemistries that resulted in higher energy density. This is pure speculation.Size in this case is the number of cells. The latest packs still have the same number of cells as the original 100 kwh packs, but changes in chemistry push the capacity (density) higher.
