fiveangle
Had my perf 3 at the Service Center with 36.4 and it was at 39.6 when I picked it up yesterday. I've had to reboot the console 3 times to "fix" audio after it goes wonky while playing from phone (Music, Spotify, Waze, Podcast, doesn't matter... they all are affected). It will play fine for a bit, then act like it's lost the Bluetooth stream. When the stream comes back, it often sounds like mono or L-R signal (tinny and shallow with mono signal). It almost sounds like there is a problem with the BT stream, and then the DSP goes belly up from miss-interpreted BT frames or something.
Some annoyances with the update:
- Can't those that preferred the directions on the right have it in a preference ?
- The trip list now has the last trip and since last charge listed first (yay !)
- The trip list now also has magnetic "snap to" edges to guide the trip sections (yay !) but unfortunately they are now not able to be manually over-ridden to in between these magnetic sections. This means that the "Since 00:00" trip and the "since last charge" trips can't be scrolled up so that both are shown on screen together (WTH ???) Also, why on earth would you design the trip section size to be larger than the available window frame space so that the sections always are confusing with the name of one trip at the top and the name of the next trip on the bottom (it is visually a mess..)
- Expected % left at nav destination is now only shown at the nav start ? I thought this used to be a preference but now it's just not possible ?
- Radio signal seems far less as I'm unable to connect to the car outside my house anymore unless I am connected via WiFi (LTE always shows disconnected). I wonder if this is noise floor has changed in my neighborhood (it's certainly possible, although not super probably) or if this change is legit. If so, it may be affecting the BT mentioned as well.
