That was super informative and could explain the heat pump issues affecting mostly customers in very cold climate where the refrigerant cannot heat enough to evaporate.
Heat pumps sound like a good idea (they are) but they have limitations. For example, a lot of split AC systems can function both as coolers and heaters. However, they have limitations on the delta of temperatures. If it is too cold outside they cannot sufficiently heat up the house. But, they have sensors and shut down if liquid reaches the compressor.
I would venture to guess that Tesla did not do sufficient testing in cold climate. The firmware updates may be related to calibrating the sensors and the rest of the system in attempt to avoid liquid reaching the compressor. I hope they are not trying to “power through” the issue by trying to move heat even if liquid reaches the compressor…
It is also possible that they used wrong refrigerant and need something with lower boiling point.
