I’ve had 3 or 4 quotes with similar generation numbers and curves, so I suspect they are all coming from a reasonably accurate, maybe even slightly pessimistic forecast (hopefully!). But I’ll double check that. Thanks for the link.
Dec/ Jan generation is forecast at 4-6 kW per day. Summer 4 months is at 28-34kW per day.
Batteries can charge at 3.6kW each pair of two on an inverter (7.2kW total). So each inverter charges 19kW/ 3.6 is 5 1/4 hours to charge fully from grid. Or if using 5% to 95% that’s 17.1/3.6 or 4 3/4 hours.
I think 2 batteries on each inverter is about the best that can be achieved with the grid charging rates of the GivEnergy 9.5’s. And the inverters input. The battery discharge rate is 5kW each inverter (so 10kW, which would seem enough for the house most of the time).
I’m viewing the north facing ones as panels that are twice the price of the equivalent panels on the south side. So to get the equivalent generation of 4 extra on the south side I need 8 on the north side, as they only produce half the amount. I know that’s simplistic and generation times will be different etc etc but the incremental cost of 8 panels on the north while they are here isn’t that much more than if I was putting 4 extra on the south. (Cost of 4 panels, plus a bit more scaffolding. Maybe 10-15% more?). I’m stuck with my roof so I don’t have the option for more on the South side. Other that not putting them on the North at all and maybe missing 1,700kW of generation per year.
My roof is L shaped. Like the fat “L” on a learner drivers plate, so there is a bit extra scaffolding for the north side but not much extra. The horizontal part of the L is the bit that faces South; ie down is south. The long bit of the L is the part that faces East (apologies I said West facing in my earlier post by mistake, I meant East, but numbers work the same).
I’m using 19,000kW pa (4,500kW of that is the car. Which will mostly come from off peak on IO).
I’m pretty sure the proposed set up will be like this;
East facing;
1x 5kW GivEnergy inverter - peak panels: 5880kW
String 1 - 6 panels (2,520kW)
String 2 - 8 panels (3,360kW)
South and North facing;
1x 5kW GivEnergy inverter - peak panels: 5460kW
String 1 (S) - 5 panels (2,100kW)
String 2 (N) - 8 panels (3,360kW)
27x 420w panels
2x GivEnergy 5kW hybrid inverters
4x 9.5kW GivEnergy batteries.
GivEnergy hot water diverter (when released!)
So the whole system (in theory anyway) kind of seems the optimum I can get. To cover winter off peak and summer generation, without overspending on Solar edge batteries and inverters. Which cost about £10k more installed. I’ve read hundreds of forum pages and pretty much guided/told the installers what I think I need to reduce my bill the most.
Only think I’m hesitating on is; what if energy suppliers prices drop? Wholesale prices have come down a lot, so in theory, we should start to see that soon. I dunno though. Will they?
Does my proposed system make sense? Am I missing anything crucial here or does it seem bang on, best case for my situation?
