how are your two inverters handling batteries? are they 2 batteries per inverter? how do they divvy up any excess?
Yes, it’s 2 batteries per inverter. Right now it looks like this;
Solar at 2.2kW generation currently (7:20am).
String 1: 1,621w
String 2: 109w
String 3: 92w
String 4: 384w
(I guess 2&3 aren’t in the sun yet). This is the biggest difference I’ve seen between strings so far.
Inverter A: Charging at 583w
primary battery: 17%
secondary battery: 29%
Inverter B: Charging at 1.17kW
primary battery: 100%
secondary battery: 91%
They are divvying it up kind of randomly I’d say. One inverter seems to be more dominant. There is some cross charging happening (as expected). Waiting patiently for the EMS balancing solution to come out. There is a battery balancing trial going on at GivEnergy which I found out about on the GE forum. I have asked to go on it. There is one trial with the EMS product and a cloud based trial. I don’t have any more info right now as to which one I’ll get on, or indeed if I’ll even get on one as I’ve only just had my details passed on.
There are two options that can ‘reset’ the amount of charge going out of each inverter:
Option 1: Pause the battery charge/ discharge on the app using the ‘play/pause’ button
Option 2: Reset one or both inverters in the cloud website using the ‘on/off button’.
There is a short period where you’ll export (between pause/play or inverter reset but both are very fast (fast fingers or fast inverter reset). This isn’t an ideal situation and only fixes the issue until the power flow changes and then they start to increase the cross charging again
I think the state of each set of batteries should eventually balance out the pair on each inverter after a while. I’ve not had a complete full-low cycle yet or grid charge. There is a difference between each battery pair which was there from the start of commissioning after the battery calibration and hasn’t quite evened out yet.
Today is looking like it should be a sunny day, so I’ll be watching it a bit more closely to see what happens.
