phil4
I could, but that whole rate thing has gone a bit "flakey" in the last update... no longer get gas prices as the most obvious issue. And hey, I can change 1 line by hand if needed.For bonus points, use the Octopus unit rate values?
Wow. Samsung now have a heatpump that can do 70 degrees at a COP of 5! Stunning:
Samsung unveils monobloc heat pump for residential applications
Samsung claims its new product is able provide domestic hot water of up to 75 C when the outdoor temperature is between -10 C and 35 C. It relies on an enlarged heat exchanger that the company claims is capable of transferring more heat compared to a conventional outdoor unit.www.pv-magazine.com
We still have daily battles about switching the oven on to "warm up" long before it's needed and forgetting to switch it off
Nope you're not last, we don't have one. I'll do a HUUUUGE shoulder of pork on the BBQ though, low and slow and then pull the meat and vacuum pack in portions. Then it's just a case of a quick microwave or steam reheat. Pressure cooker for veg.Air Fryer ? If its just small quantities of food, for one or two people (at a sitting), I've found that its both much faster and uses less energy. Mine doesn't need a pre-heat at all. I also use it, on the re-heat cycle, to warm things that I would have previously done in the microwave ... it does a much better job of "warming through"
Apart from some Roasty Veg, or freezer-to-table stuff, which I find it does really well, a recent 1kg-ish chunk of Pork shoulder was done in half the time it would have taken in the oven (my Air Fryer has a probe, just push it in and choose the type of meat and Rare...Well done
I thought I was the last person on earth to get one of these, so sorry to those of you in the choir stalls that I'm preaching to
We just got one last weekend. Still getting to grips with what can be done with it but we did chips (home made) in about 25 minutes start to finish and they were great.Air Fryer ? If its just small quantities of food, for one or two people (at a sitting), I've found that its both much faster and uses less energy. Mine doesn't need a pre-heat at all. I also use it, on the re-heat cycle, to warm things that I would have previously done in the microwave ... it does a much better job of "warming through"
what is everyone's personal rules for battery charge settings vs estimated solar? eg here is my PV-GIS estimate of my average daily generation across the year
colour coding added by me as a rough estimate - red I'd probably charge to 100% and any solar is a bonus needing me to top up less at night (if I can make it to end of day); amber was thinking to charge to 50% but I might increase a bit? Green I should be ok with like 25% and use the solar to charge up during the day?
only had mine installed since May so hitting the first lower months now
Mine is very similar to that.
I guess I’ve got about another 3-4 weeks before my 15p IO export is sorted, then it’ll just be 100% overnight all the time.
My daughter is an aspiring chef so she often will "pop the oven on". The givenergy app has become my new thermostatWell, judging by your earlier comments about Mrs C. McC extravagant use of Oven I expect your Air Fryer has paid for itself already!
Just to update, spoke to them today as my whole account is going mad.U-oh. Have cancelled my export move for now on the back of this. May just be confusion in contact centers while things get set up, but will wait a week or 2...
A mess with two energy suppliers? All I can say is “good luck”. Sounds like you’ll need it!Just to update, spoke to them today as my whole account is going mad.
Export transfer hasn't been cancelled, MPAN has moved, 15p export confirmed fully compatible with IO. Also mixed up in a dispute with my old provider about transfer readings which is making my account read pretty weird and stopping me getting my hourly readings, maybe. Internal escalation now in progress, but looks like 15p export is still on \o/.
Hi,Just to update, spoke to them today as my whole account is going mad.
Hi,
Are you seeing the 15p export rate in the Octopus app already or still 4p?
Just wondering how long it takes to show up (become active) on the new rate?
My tariff shows “Octopus Outgoing smart export guarantee….4.1p”. Although it did say 31p for a couple of days (which I was hoping would stay )
(My export was set up on Friday and I sent the meter reading photo yesterday.)
Thanks for that. I’ve been emailing. So maybe takes a bit longer…. And it was over the weekend.Yes, was showing in the app later that day after the phone rep sent something to the smart meter team. I did my opening read over the phone with the rep I was talking to.
Have subsequently realised that a profitable export rate breaks (in a good way) all my spreadsheets. They very much assume maxing out self usage to the extent I didn't do any calcs for export. Guess I'll bin all that. I do wonder what it could do for ROI.
Phone them 100% more helpful I found.Thanks for that. I’ve been emailing. So maybe takes a bit longer…. And it was over the weekend.
Yep. Calcs out the window…
Basically all your generation (or a large portion of it) can now go out at 15p.
Any of the 100% solar battery imported in the IO off peak window that is spare can be discharged in the evening as well. (Maybe not so much in winter though!)
That’s as far as I’ve got so far. Maybe it’s that simple. Maybe there could be a bit more to it?
But I can’t see it if there is.
Ok,Phone them 100% more helpful I found.
