Something wrong with my mph/rate of charge at supercharger?
Discussion in 'Model S: Battery & Charging' started by redi, Mar 14, 2015.
  1. redi
    redi 2013 P85+
    DFW, TX
    I happened to visit the new 135kw Ardmore Ok supercharger today and arrived with a little less than 30% SOC.
    During the visit I had 3 other cars (we were all on different superchargers (1,2,3)). Despite seeing 373V/155A at a peak I never saw a "mph" rate above 196mph, and it was often less even far short of the taper. I have noted in the past seeing a "mph" rate approaching as high as 290mph at other superchargers on my car.
    Thinking I may have been on a weak charger, I swapped with one of the other guys (moving from 3 to 1) and still saw identical numbers charging my car.
    The other guys at similar SOC were seeing 270-290mph. All were 85, one a year older than mine, one almost brand new.
    Anyone have any idea why my effective charging speed (mph) has diminished in spite of what I observed others getting today under identical (time, temp, SOC, V&A) conditions?
    Thanks
  2. markb1
    markb1 Active Member
    San Diego, CA
  3. redi
    redi 2013 P85+
    DFW, TX
    Upon digging around, I found an old screen capture that showed significant higher amperage, which must explain the difference.
  4. FlasherZ
    Yup. See the other thread. Call the supercharger number and report maximum of 60 kW charging, then file a ticket with your service center saying you only received 60 kW when charging at a supercharger.
    This assumes, by the way, that you're in a stall with no car in the other paired connection (e.g., you parked in 3A and there's not a car charging in 3B). If not, you were sharing current with another car that was charging.
  5. AndreyATC
    AndreyATC Member
    New City NY, USA
    I got some decent charging rate in CT
    20 miles before getting home
  6. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Perhaps this is related to a specific Software revision? Perhaps it is temporary until the contactor which has been proactively replaced for some is complete for the fleet. Just a guess.
  7. FlasherZ
    The contactors that are being replaced are the main pack contactors that tend to cause the dreaded "clunk", I don't think they're replacing the contactor that connects AC charger vs. DC battery.
  8. redi
    redi 2013 P85+
    DFW, TX
    #8 redi, Mar 14, 2015
    Yes. Granted a brand new 135kW supercharger. I happened to have visibletesla on at home and it shows ramping right up to 196mph. After about 15 minutes at 50% I moved over to stall 1 and saw the same thing but then the rate almost immediately started ramping down. I was plugged in for over an hour.
