Not sure, but I suspect that a strong magnetic field could raise havoc with the electronics on board the rocket. They can't rule out any possible solution, that bounce across OCISLY is an obvious concern for long term reliability.
Judging from the video, at touchdown the Merlin engines seem to be producing just enough thrust to create a momentary hover. At that instant the rocket would become part of the air mass, drifting it downwind across the deck. Have no clue as to how much stress those carbon fiber legs can stand, but I wonder if SpaceX engineers will consider dropping it in from a couple of feet? I'm guessing they are currently only using a radar altimeter system to gauge the altitude above the deck. Apollo lunar modules also used a radar altimeter system, but backed it up with several 6 foot probes for precise information. At first contact the commander would manually close the throttle and drop it in. (Although on A11 Armstrong supposedly maintained some thrust until the legs touched the surface) Just a small jolt in one third G. They'll probably consider multiple ideas and it will be interesting to see how SpaceX eventually nails this issue.
I'm outside my field here and I don't know the total payload mass but the collection of small-ish sats on the manifest indicates we're a tiny, tiny portion of the FH boost capability. We'll be so light they'll load up with tons ballast for certification. Plus low-Earth-orbit (LEO) allows even more payload mass than GTO (where Direct-TV sats etc, pass the time).Thank you sparky for those details. You said your payload will be light. Any approx numbers ? Just wondering what is considered light for FH, and how does that compare to F9 payload that went up last Friday.
Thanks
A relatively simple solution seems to be to expand the deck of OCISLY e.g. until it is as wide as it is long. In case of wind with a constant component other tricks with the deck could be: purposely landing off-center up against the constant wind component, or even a light tilt of the deck to lean the center of gravity of the rocket stage into the constant wind component. I guess Space X could validate their recovered first stage while practising such landings.
As for magnets in the deck, they could consist of many small ones, each with a relatively localized field, and then only those directly under the landing feet would be enabled. The first stage has its apogee at about 140 km altitude, i.e. the ionosphere with nasty, hard X-rays and ionized particles, so I assume the electronics are radiation hardened, which may or may not include protection against an EMP. How that would help if at all against a magnetic field around each of the landing feet, is a good question.
Anyway, I will look forward to the next Falcon 9 launches. As for Elon, I actually hope he will spend most of his time ensuring that those 325k Model 3s are manufactured in a timely fashion to acceptable quality standards.
The F-9 can put about 13 metric tonnes (13,000 kg) into LEO, so the FH is 4x that on paper. FH is really designed for competing with the Ariane-5 for big commercial payloads like Intelsats going to geosynchronous orbit. IIRC, FH has 2x the boost as the Ariane-5. And of course it can send a lot of stuff to Mars (~13 kt).
Sorry, yes you're correct. That was sloppy. 13 metric tonnes not 13 thousand metric tonnes (kt). That would be a lot!I think you're mixing units here. Should that "13kt" be 13 000 kg again?
Yes, and that is why the Falcon Heavy won't be the rocket used to get people and cargo to Mars, for that we need the SpaceX "BFR", much greater payload capacity.I think you're mixing units here. Should that "13kt" be 13 000 kg again?
So where's the barge/rocket now? I thought it was supposed to be back in port by Sunday.
Sparky. In the event that your satellites allow you to attend the Falcon Heavy launch, allow me to be the first here to volunteer to accompany you as your Valet. There may be others far more qualified on the thread, but none with the same abilities as a sycophant and glorified assistant. My skills are at your disposal.Sparky, very cool, thanks for sharing and participating on TMC.
