adiggs
Totally has nothing to do with anything, but the Tom Lehrer reference made me go fishing for New Math.
Finding the best solution to those troubling surface winds would be a challenging, yet fun job to have at SpaceX. Since these rocket landings aren't required to be man rated, the engineers probably have more freedom to experiment. Your crosswind landing suggestions would be worth a look, especially targeting slightly upwind from the central X. I believe both the RTLS and drone ship winds are good to at least 15 knots. With practice they might even be able to raise the limitation someday. Who knows? If Elon could just find a tall ghost ship like the Queen Mary, just anchor it a few feet upwind of OCISLY and they'd be all set!
Here is a really cool advantage (I think):
5) The rocket engine cannot be throttled very far down, so the landing is hard to control because you have too much thrust just a the point of landing, which makes it critical to turn off the engine just at the right moment. Now, if there is only sea water below the central part of the landing deck, the deck could actually be perforated, with holes dimensioned so the minimum thrust of the single rocket engine would be more suitable for the touch down. Since the deck is likely a sandwich construction, each hole could consist of a pipe connecting the deck layers, providing additional strength.
I suspect a floating platform provides enough stability as more often than not rough seas and high winds come together...and high winds scrub launches.
I didn't explain properly--My guess is that the launch criterial/limits/rules for weather likely envelopes the acceptable conditions on the barge. In other words, if you're okay to launch, you're probably okay to land.
Conversely, If the winds/seas are too rough to land, the launch is probably red on weather anyway.
The ocean-landing site is on the order of 300 km out to sea and although the weather conditions there may very well be correlated with those at the launch site, they can certainly also be different and worse. So, yes, there is probably a good chance that OK launch conditions will occur along with OK ocean-landing conditions, but this is not a given.
That's a remarkable rendering- great to watch. Reminds me a lot of The Thunderbirds....I ran across this incredible tilt-shift edit of the landing. All credit to /u/saxmanatee on reddit, who labored on it, and apparently edited it frame by frame to get the effect.
