Would this have enough power to supply Rick's front camera switch as well as a radar detector system? (I realize I should try to get the exact power requirements of both those units, and I will do that, but I just thought I'd post here to start.)
I recently had an issue that required the replacement of my wiring harness (at my expense) because of bad installation work by a third party installer. I'm about to have a different installer reinstall the front camera switch and the power connection to the radar system. The plan was to use "add a fuses" in the fuse box, so as not to tap the wiring harness, but if this could supply power for both, it seems like a better option.
Also does anyone sell the correct connector that mates with the connector shown in the picture, that our necessary wires could then be run into or something? If so, what would it be called?
Thanks.
Edit: I just found part of my answer. Apparently my radar detector system uses very little power, so this is looking promising:
Q: How many amps does the 8500ci in power consumption when fully used with laser shifters and without?
A: Less than 1A, about 700mA max. A 2A inline fuse is included with the system.
Edit 2: Looking more at the picture in the first post, does the open connector with the black and white wires coming out of it have to connect to the open connector where the red wire with power is? If so my question above about finding a connector doesn't make sense, I guess. If not, why is that other connector not connected to anything?
If those two connectors do have to be reconnected, how would our new wires be added? Through the back end of the connector that currently has the black and white wires?
I realize these questions sound ridiculous, but after being out close to $2000 because I trusted the last installer, I want to micro-manage the next install, and want to pre-purchase all the correct parts, and understand exactly what should be happening.
Basically the only things you wouldn't be able to run from this spare 12V connection would be a large inverter or audio amp. Just about any other 12V accessory (radar, camera, etc) should work just fine, even if you have a few of them. 11A/12V is quite a bit for small devices. I'd be very surprised if you could find a radar or camera that used more than an amp or two.
Is there a constant on 12V power source in that same general area that can be tapped into?
I need a switched and constant source for the ThinkWare F750 dash cam I'm installing this weekend.
Worst case I can tap the 12V in the mic area, but I'd like all the power to come from the same general location if possible, since the the hardwire cable for the ThinkWare has the fuse at the far end.
I use the OBDII connector in the driver's footwell for constant 12v to power my dashcam and front facing camera. No tapping/splicing required.
Why do you need switched for the dashcam? For parking mode detection? My LUKAS does that via motion detection and/or GPS, no switched wire needed.
That is a nice form factor. I did not see it when I was looking, probably since I was focusing on latest models (they generally have better video quality, especially at night).Ahh, I have the LUKAS 5900 dual camera set up... only needs constant power.
It's a slightly older model, but I really like the form factor (no LCD screen). The resolution could be better though for reading license plates.
I have a Sti-r plus self install and a 4 head laser system running through it. Like WK said, just probably no invertors.
The connector is quite large, around 45mm long:
The male is 18 x 19mm and recognized by the lip on the side and top.
The female have lock integrated in the housing.
The pins is square.
Have not been able to locate it at Mouser, have not given up quite yet. :-(
This post has good info about the constant 12v connector in newer VINs #32How can I tap into 12V power from the rear view mirror base?
You can add a pin to the female side and hook you up to the connector.
Then need a power theefe plug to connect the black. (earth)
I will get both male and female, make a T connector.
Unplug the plug and connect my plugg between? then I have a plug and play solution for 11A power.
Have already done the same for Trunk and Frunk light.
I hate to use power thief on any cables.
Only solution I like is one thst can be disconected with no trace or damage to any cables.
I guess it is a common connector, it is just so many to look through.
