I know I'm resurrecting an old thread, but I figured I'd post on the details of the connector and how I tapped into it. It took some research to find the details, so it probably would save people some effort if they want to do it the way I did it. I wanted to keep the Tesla harness unmodified, which meant making a custom harness that gave me the 12V and ground separated. I have a 2016 Model S Pre-facelift, so this is what worked for me.
View attachment 721962View attachment 721963
The connector is a Male Yazaki Yesc Kaizen Unsealed 2.8mm 4 pole:
7282-6446-40
The female end is
7283-6446-40.
Also need at least 3 of each of these terminals when using 18AWG wire, assuming you want to pass the 12V though still.
7114-4111-02
7116-4111-02
The Red/White wire is 12V. Ground is the Black wire. I basically made a passthrough harness, then tapped into the 12V and the ground of the passthrough. I used buttsplices since that's what I had on hand. I didn't have their actual crimping tool for the terminals, and had to resort to using two separate manual crimp tools I found that were close enough sizes, one for the wire and one for the insulation grip.
View attachment 721965View attachment 721966View attachment 721967
I'll be honest and admit this is probably overkill and most people are better off just using a positap to get what they need. The connector parts weren't easy to source since nobody uses this particular one anymore in current car production. I actually have some leftover parts, enough to make another 1, maybe 2 if I'm careful.
