Are you confident that the SR+ will accept even the 145 kW of the v2? And if so - based on what, since many seem to suggest it will not even reach 120 kW?
At a very high level, the battery charge rate is limited by three things:
1) ability to apply the desired amperage to the cells
2) ability to dissipate the heat generated due to internal resistance at high amperage
3) ability of the cell chemistry to accept the power without damage
The LR cars can charge at 250kW or more. 256kw has been seen. This means that the wire harness from the charge port to the battery is capable of the amperage to support 250kW for at least a short period of time. It also means the battery cooling system is able to remove and dissipate the thermal energy created by the charging process. (IIRC, Li-ion charging is actually endothermic, but the IR creates the heat.) The capability of the cooling system is defined by parameters such as coolant volume, coolant pump size/flow rate, heat exchanger size/efficiency, contact area on each cell, etc. In order to preserve commonality and simplify assembly, I expect both the charge port wire harness and cooling system components are the same across the Model 3 line. This means they're sized for 250 kW into a ~75 kWh battery.
We know the SR battery has about 2/3rd the number of cells as the LR battery. So if we charge the SR battery at the same C-rate as with the LR battery, it can take 0.67x250= 168 kW. And we have every reason to believe the SR cells themselves are the same as LR cells...same chemistry and C-rate capability. So the SR battery can take ~168 kW at the same level of stress as the LR battery can take 250 kW.
Additionally, if the charging harness and cooling systems are common, they are sized to handle 250kW, so the SR cars have excess capability for SR battery charging at 168 kW. If anything, I expect the SR battery to charge at a
higher c-rate than the LR. This would be made possible by using this excess cooling system capability.
In summary, I expect the SR to exceed 145 kW charging. It's likely to be at least 165 kW, if not higher, depending on exactly how many cells Tesla included in the SR battery relative to the LR battery.
