sillydriver
That makes sense.Well, if nothing else, you may then want to try 80 amp charging when it is cold, and you need to heat the battery, but in the spring and summer, when that's not an issue, consider dropping down to 56 amps.
What happens in the individual cells is a chemical reaction. No 2 cells, and a 85 kWh battery contains 7104 of them, are 100% the same. So after some charge/decharge cycles, they get slightly "out of balance" = they do no longer all sit at exactly the same voltage. This reduces the overall performance characteristics of the battery. When driving the car up to a very low SoC, the cells sitting at the lowest voltage might experience more "stress", which impacts their useful lifetime. To keep your battery pack in the best condition, the individual cells need to be "balanced" every once in a while. Thanks to the research of our much respected forum member wk057, we know that the balancing mechanism is triggered when the battery is charged above around 93% SoC. So this is essentially when you do a range charge. You don't have to do anything special to trigger balancing, except do a range charge e.g. once a month or once every quarter. It will make sure all cells are calibrated so they are all at the same voltage level again.
Since I keep my cells at a low SoC most of the time, the battery management system has a lot of trouble measuring / keeping track of capacity. I know this because the range displayed in my car decreases faster than the range displayed in cars that are charged to e.g. 90% on a daily basis. This is because it is very difficult to keep track of a cell's capacity if it is not completely discharged and charged. So in my case balancing regularly is even more important to make sure individual cells don't get too far out of balance with the rest. This could result in over discharging or over charging these individual cells which is very bad for their health.
My problem with this is that even someone who deeply discharges, say 70%->30%, on a daily basis sees more apparent loss than folks who discharge 90->75% daily. It's more than just the depth of discharge that Tesla uses to calculate capacity.
Can you share with us the algorithm that Tesla uses to calculate capacity? I would be most interested in learning this. Especially the weather effect (temp) and if that is mostly taken into account and logged by the Model S algorithm when the car is on the road and running or in a quiescent state, say parked overnight. Also is the algorithm more accurate if you are charging to a 90% State of Charge and if not, what is the penalty?
So in your case, after you do a range charge, do your subsequent 90% charges restore some of the "lost" miles?
I suspect tesla doesn't respond because they've gone to great pains to design BMS to idiot-proof the system. They do not want owning BEV to be an arcane lesson in EE. Unfortunately, that leaves gEEks guessing, which I suspect many complain about but secretly love....
I know quiet a few well heeled professionals who own Teslas.... have no time to geek out... and just plug in ...and then.. in the morning GO.... no fuss no muss and when asked question like I have asked on this thread... they knit their brows... and become dismissive rather quickly. Recently, when I brought up the topic of balancing the battery with one of them, the answer was "Look, I have no time or inclination to do that at all..." Funny, this world of Tesla owners... for sure but certainly expected and normal... I on the other hand am probably NOT... normal that is
