So I was watching Now You Know on Youtube and Jessie said something about using the motor regen to direct to a strip heater when the battery is too cold to take the charge (for cabin heat or to heat the battery). So why not have a “brake pipe” (electrically shorted pipe or finned metal strip) that takes all of the current that the battery can’t take? Does anyone know what the max power the motors can regen and what the max power the battery can charge from regen is? If the brake pipe takes all the heat you could race will smaller lighter brakes and they would last longer. Also the pipe could get much better airflow and you would not need to duct air to the brakes.
