I've had my subs for about a year now and I balst them everyday. I haven't seen any negative hit to my range
Does your infotainment screen flicker whwn you blast it? I have the stock HiFi system and my screen flickers when I blast that
My screen doesn't flicker. If anything, the camera image vibrates and I can see that happening in the rear view image.Does your infotainment screen flicker whwn you blast it? I have the stock HiFi system and my screen flickers when I blast that
For those with sunroofs, do you really absolutely need to drill the firewall? Is there no other way to feed the cable through?
There really isn't even enough space to fit a drill in there..
I took delivery on a 2015 S 85D in the latter part of April. I've had 2 quotes for a subwoofer and amp installed. I'm in Maryland. First quote was $4,000 to $4,500 depending on enclosure outside finish, and second quote was $3,200. In both cases, the amp and sub were less than half of the total cost. I had no idea these shops were getting that kind of labor rates. A long time ago, I could get an enclosure made for $400-$500, and an amp installed for $150.
In my previous Model S, I went with the NVX Boost system which is designed for the Model S. I got a place to install it for $400, so all together it wasn't a bad deal, and it didn't take up too much space in my hatch.
B.O.O.S.T Series Powered Bass Kit for Tesla Model S
The base was really strong, and amazing.
Who installed yours for $400?
I am not sure how the HiFi system draws power from fuse block, does it have its own fuse or does it share the MCU? On aftermarket systems we wire directly to battery post, this helps reduce current draws on internal fused system (its wire is engineered for what the car needs not much more, not just teslas all autos are this way). When you run your power line for any aftermarket amp, you choose the line and fuse for what that system will need to draw as well, with a bit of headroom.Does your infotainment screen flicker whwn you blast it? I have the stock HiFi system and my screen flickers when I blast that
Couple folks with UHFS have dropped an 8 inch soundqubed sub into the stock sub box and upgraded with a light harmonic amp.
I have a custom box made that fits a 10 inch infinity kappa perfect in the stock space. Hid a class D (key for range) amp under the box. I also added a kill switch to the remote turn on which I hid under the trunk cover to turn off the sub for longer road trips if it starts effecting range. Though I doubt it will too much, my amp is rated about the same power as the UHFS amp and is more efficient.
Ordered a custom box from a shop in Florida and installed it all myself.
I have a 10 in the factory box with an amp in the frunk.Does anyone on here have aftermarket subwoofers installed?
I'm a big bass head and audiophile. Just got my MS and one of my first ad ons will be an audio upgrade. I'm looking forward to some subs in this. HOwever i want something bigger than the NVX i see so many talking about. Anyone here have a good subwoofer set up? How does it affect range, battery etc? I'd love to see some pics)
I’ve been running two NVX amps off the 12v on my 2017 (aug 30th build) model S with no issues for two years now, so maybe resolvedBe very cautious about connecting the amp 12V lead directly to the Tesla battery. If the Tesla 12V charging circuitry doesn’t “see” the amp current draw, the battery won’t be charged properly and will need premature replacement, resulting in the “12V battery requires service” message. I just went through this with my 2012 Model S, and elected to run my aftermarket sound system on a separate AGM battery instead. Perhaps this is not an issue with the newer S or X (different battery location) or Model 3.
Oliver Barrett
Sunnyvale, CA
Very nice work!!! Love the video- how is the amp up front? Is it exposed to the elements?10" Subwoower install in my model :
https://store.audiodesignscg.com/product/tesla-model-s-subwoofer-box-phantom-fit/What's the name of the shop did you order the custom box from ?
