AMPd
Harris ranch has them too?No. Many others including Hawthorne, Barstow and Harris Ranch have had battery backup for a while.
I know Tejon Ranch also has stationary storage.
Or vice versa: Green is charging, red is done. Anyway, this was discussed extensively on the FV thread (I think) with fairly universal praise. I strongly feel that if everyone is made aware of the charging status of a car, everyone would be much more careful of leaving their cars unattended when done. Now, instead of retrofitting SC equipment with lights, it could be a color indicator on the charging port. Very easy to do with software.Wouldn't this problem be solved (at least as far as inconsiderate Supercharger stall hogs) with the Supercharger bays having two lights: green, meaning no charging is taking place and the stall is putatively available, and red, indicating active charging is taking place and the owner isn't being a lout.
This setup prevents ICEing. Some are pull through. Others are back-in. Even though it's busy, it's I've never seen a wait. Or ICEing except Christmas right after installation. I have taken many friends for a supercharger there or Hawthorne. Least desirable spots on the entire mall property.
Giant rotating Tesla sign?Taken 20 minutes ago, looks like good progress on the supercharger. The supercharger cabinets are in place, the enclosure seems to be in progress, and the transformer pad concrete has been poured. And some other things that I can't identify And the red beam sticking out of the ground, I have no idea what that's for.
No, pole dancing available to entertain bored Tesla drivers supercharging.Giant rotating Tesla sign?
Great pics, btw. I'm also curious if others can describe/dissect the various components.
That's what I initially thought but the column was way too tall to be part of a canopy. I was on the 2nd floor and it looked like it extended up to the third floor. Also, there's only one column and it doesn't look like there's another one going up anywhere nearby.My wag is solar roof posts.
The red column I took a picture was at 33.775857, -117.872238 (where the gray dot labeled "Mainplace Drive" is on your map, not the red marker). It's right next to the location of the Superchargers. I do think it is not related to the Supercharger, but I am curious what it is though. They just installed a huge sign across the lot with a gigantic screen and sign. I don't think they would put a sign where the red column is, the spot is obscured by trees and the column isn't that tall (compared to the other huge sign that just went up). You really can't see it from the freeway.DJung, your pics of those huge non-Tesla like footings with those two very tall red columns and heavy duty box with anchors look like they are at the corner of 33º46'40.05"N 117º52'14.41"W (I matched the freeway signs and angles, and other stuff), whereas the Tesla SuperCharger is at 33º46'33.18"N 117º52'19.88"W (I matched the stores and angles, and other stuff), about a thousand feet away on the other side of two big parking structures. I don't think those big footings are related to the SuperCharger at all. Nothing in the very un-Tesla like big footings is described in the original application, and the rest of the SuperCharger pictures matches the original application fully.
"... now with Supercharger!"I've seen YESCO (Young Electric Sign Company) trucks next to one of the two large red columns. I was told early on that several electric signs would be erected. Another, with two large digital video screens (facing north and south) appears to be near completion. I will post a picture of that sometime later today. So, I'm pretty sure all of them are signage of some sort for the mall and have nothing to do with the SuperCharger.
wow, thanks for the update! all those trucks are part of the supercharger construction crew?As of 10:15 or so today. The first Tesla branded item! View attachment 195099
thanks for the update. Please check tmr instead more progress.Yes, as no work seemed to be occurring on the large sign to the right of these pictures. I counted at least seven workers, three to four of whom seemed to be electricians. One of the trucks at the top middle contains asphalt that I assume will be put in once the wiring is complete. We'll see. I may check again at the end of the day. If not, tomorrow.
