I have seen people waiting in line at Supercharger stations. Does the system recognises how many chargers are occupied and indicating it before suggesting a Supercharger or sending you to it?
noI have seen people waiting in line at Supercharger stations. Does the system recognises how many chargers are occupied and indicating it before suggesting a Supercharger or sending you to it?
they will block out SpCs that are not operating.Sounds like possibly an easy software feature to add via the internet connectivity. Showing a map of local stations and a number of active stalls (and also ones maybe down for service) could be a very useful feature of the system.
showing how many units are occupied is not a good use of resources because many SpCs are in areas with limited options and are the only choice for many miles around so you if you're on a trip and need a charge you will need to stop at that particular SpC regardless of how busy it is and also because if you look at a chart of usage 10-15 minutes prior to arriving in the time it takes you to arrive things can easily change.
The situation varies in Europe - the distances between charges might allow one to consider another station instead of waiting in line......showing how many units are occupied is not a good use of resources because many SpCs are in areas with limited options and are the only choice for many miles around....
Figuring out wait times will be challenging - even if every car is running under navigation and passes the time it needs back up to a server, there are still large variables in it.
Having a computerized queue and showing your place in it is certainly easy enough - and might be an outgrowth of what I'm hoping they do, where when you approach the Supercharger it tells you which stall is the best one for you, with a nice chart of the locations on the center console (and maybe an option for fully automatic parking in that stall on AP1 cars.) When more than half the stalls are filled, it'd pair you with the most charged car; otherwise it'd use some algorithm to level the usage among the available unpaired stalls.
How about this. If they cannot do "SuperCharger activity logistics" - how are they going to do "connected car autonomous highway chaining" ?
I would just start with the basics and not over think it. 8 spots available 3 spots currently charging.
I think your last point is where the rubber meets the road.I'm sure they can give you a guess. My point is that the sessions are long enough and variable enough that it will be a guess, and could easily be off by five or ten minutes - it'd be about as accurate as restaurant wait time for a restaurant with only a dozen tables.
The other thing is, Tesla is putting a bunch of money into reducing the chance it'll happen in the future - is a dollar better spent there, or in software to tell you how long the wait is?
Supercharger status doesn't help roadtrippers, who usually have no options. So we're asking Tesla to invest time and resources into helping local chargers.
It will probably happen soon enough. It shouldn't be a priority, though.
