Tableau tips. When you interact with a map, a menu bar will show up in the top left corner of the map. The bottom item is an arrow that, when clicked, exposes a tray allowing you to select the behavior of your fingers or mouse actions. You can select to zoom, move, or select. Eventually, I'll build some maps visualizations that allow you to select on the map, which will then filter lists or other displays. For example, I'd like to build a map that links to a dynamic leaderboard. In that case, when you filter or select on the map, the leaderboard will dynamically adapt to what is displayed. Right now, selecting objects on the maps don't do anything.
