Recently I've decided to take advantage of my free 6mo of Super charging since my home electricity is expensive (0.25/kWh) and I don't have solar yet. I've been getting what I would call poor SC performance.
Now it is winter here.. But I've been trying to make sure my battery is warm before I start. I've had full regen each time.
My best charge was when the battery was at 19%. I got like 113kW charge rate to start. Then it tapered right away?
Isn't it supposed to start to taper at like 60%?
All my charges have this taper no matter where I start. And my charge rate starting point really depends on my starting SOC. I would have though that would get the max until hit like 50% or 60%. If I start charging with 50% SOC, I would think I would get the same rate when I got to 50% when I started with 20%. But If I start with 50% it's much less. I've seen other curves like this from electrek from an European 175kW CCS but with a super charger.
This is what I would expect. Flat, constant rate until a certain point.
So is it just charging weird because it's cold outside? Or is there something weird with my battery?
I've seen this taper/slow rate at 2 different chargers.
What do you guys charging curves look like?
Thanks,
Jim
Thanks,
Jim
