I've been playing around with lithium batteries is EVs for some years now, and the only real issues that tend to shorten their life are high temperatures (not a problem with the Tesla pack as it's actively cooled) high numbers of charge discharge cycles using the whole capacity of the battery and failure to allow multiple cell packs to balance properly, occasionally leading to cell, or cell module, failure.
It's only really the latter issue that might, possibly, give some cause for concern after lots and lots of rapid charging, with no AC charging. When rapid charging, the battery management system in the pack doesn't really do cell balancing, as the charge current is too high. This doesn't normally matter, as in practice Tesla cell modules tend to remain in balance for long periods of time without intervention. It is possible, though, that if a car was never AC charged, it might eventually end up with the pack out of balance.
I'm certain that the BMS can not only detect this, but probably show some sort of warning message, or just reduce the rapid charge rate. If you think about it logically, the battery pack can happily deliver over 300 kW when driving, and get charged at around 70 kW or so from regen, so it's operating in the same sort of current range as a rapid charger all the time it's being driven, albeit not for prolonged periods of time.
From what I can gather, from monitoring AC charge current, the BMS seems to do most of the cell module balancing at the end of an AC charge, over a period of maybe fifteen minutes to half and hour. This bit of housekeeping keeps the pack in good enough order that it can then tolerate a few rapid charges without getting out of balance.
If planning to rapid charge a lot, I'd try and arrange to have an AC charge to 90% plus maybe once a month or so, just to give the BMS a better chance to do its thing.
It may be that the BMS will switch to being able to balance any time the car is parked before long. I have a BMS unit that does just this, actively balances the pack when it's neither charging or discharging and for the month or so I've been playing around with it I'm impressed at what a good job it does. It wouldn't surprise me to find Tesla start using this technique before long.
