The location where I want to put the NEMA 15-40 outlet can only be done via surface mount since the cable run has to be done along the external wall inside the garage. By code, I need to use conduits. However, the 6 gauge cable is very rigid and I need to run it through several 90 degree elbows at the corner and where the cable comes out from the wall via the basement.
If you have done a surface mount, is there a trick to get the cable through elbows ? Do you have pictures you can post or any link that can help me? Thanks.
