Then... why so little to show for it?
I think GM has been fairly busy in vehicle electrification:
EV-1 & S-10 Pickup 1997-1999:
New battery packs (lead, NiMH)
New motor
New inverter
New charging equipment
Hybrid transit bus 2004-2017:
New battery pack
New RWD hybrid transmission with power split modes
New motors & inverters
Two-Mode trucks and SUVs 2008-2013:
New battery pack
New RWD hybrid transmission with power split & fixed ratio modes derived from bus
Saturn Vue SUV ~2010 (never sold):
New FWD hybrid transmission derived and repackaged from RWD SUV/truck
Volt 2011-2015:
New battery pack
New FWD hybrid transmission with series &
power split modes
Spark EV 2014:
New battery pack
Modified motor from existing design
New inverters
Spark EV 2015-2016:
New battery pack
ELR 2014:
Reuse 1st gen Volt parts
ELR 2016:
Modified battery pack and hybrid transmission for increased power
2nd gen Volt 2 2016-2017:
New FWD hybrid transmission with power split modes
New inverters
Malibu hybrid 2016-2017:
New hybrid battery pack
reuse FWD Volt hybrid transmission
New motor
CT6 plug-in hybrid 2017:
Modified Volt battery pack
New RWD hybrid transmission derived from
Volt
New motor
Bolt EV 2017:
New battery pack
New motor & gear pack
New inverters
That’s many new electrified vehicle designs redone mostly from scratch each time and several modified derivatives.
Except for the ELR borrowing heavily from the 1st gen Volt and the Malibu borrowing heavily from the 2nd gen Volt these are all major “from scatch” engineering projects. Basically 9 major new designs including 6 new hybrid transmission designs each with unique complex control firmware during the timeframe that Tesla did 3 simpler BEV designs with the Roadster through to the Model 3 since the S and X largely share the same tweaked powertrain.
The good news for GM is that they have a fairly solid and mature set of designs now that they can mostly borrow and tweak and drop into many various car models. The newer Volt/Malibu hybrid transmission is designed to be a physically compatible drop-in replacement for GM’s 6-speed conventional automatic transmission used in various car models. The CT6 is an architecturally extended version of that design although repackaged into a RWD layout and is suitable for being dropped into pickup trucks and SUVs. The Bolt’s skateboard-like battery and FWD motor and gear box is suitable for reuse or derived variants in other FWD BEV models.
