LargeHamCollider
Battery cells != scalable
The one ought to set expectations for the other.What does one thing have to do with another? Assuming it's possible, any complaint should be based on option cost.
It seems the EPA rather agrees with you.Simple rolling resistance... RAV4 EV has large tires and lot more wind resistance. it's KW per mile is going to be much higher than Model S/D or Roadster.
I believe that if Tesla Motors has a starting internal cost below $110 per kWh for battery packs from the Gigafactory, 70 kWh is achievable at the $35,000 base price and would allow for up to an initial 12% profit margin. 60 kWh would work at $128 per kWh or less.As I've said previously, Tesla will put in as much as they can, taking into account all parameters, including pricing, available technology, and being able to survive as a company. A base model 70kWh does not allow a $35K vehicle and 100kWh doesn't fit into a Model 3 using current technology. Their more aggressive product ramp means they have less time to wait for more cell chemistry improvements. The Model 3 you seem to want Tesla to sell is quite a few more years down the road. I'm glad they aren't waiting.
They called them 'Engineering Prototypes'.I don't think so at this point. Weren't they saying the 3's were production ready prototypes, or something to that effect?
I believe it would be...Anyone here think there will be only one battery available for the Model 3?
It would have to average below 202 Wh per mile over the entire 5-Cycle test to get just 300 miles. If you use the magic ~194 Wh per mile number, you may see 318 to 320 miles range. A 90 kWh battery pack might allow for about 350 miles range if you can keep below 208 Wh per mile. I believe that in The Real World you must allow for both Range and Performance. If instead of a 280-to-330 Wh per mile efficiency (as some have observed lifetime with a Model S), the Model ☰ can achieve even a 224-to-264 Wh per mile daily operational consumption...? Then I expect a 300 mile range in the Real World would require an 83 kWh to 98 kWh capacity. If they limit it to 194 Wh per mile as an average consumption, I am afraid it would drive like a Camry. Of course, Tesla Motors could simply 'cheat' like Volkswagen did, and just have the car refuse to go over 194 Wh per mile if its systems detect it may be going through the 5-Cycle test... It is all software controlled, after all.Keep in mind a M3 with a 75kwh pack would get over 300 miles EPA range, I think it's a little much to complain when this option would have more range than the the longest range MS currently available.
While Tesla remains supply constrained, this is incorrect. Until that is addressed, nothing that they change will grow the number of purchases.If Tesla installs larger batteries in their vehicles and allows software updates to increase mileage range at 5 kWh increments or larger and advertises the capability, more people would purchase their vehicles.
Battery tech is constantly improving by 5 to 10 percent a year while production cost decreases. So 10-20% more range for same weight and 30% less cost by time production starts. Yet total weight is down to 3500lbs. The 3 platform should be expected to have more range compared to the S.The one ought to set expectations for the other.
Fwiw, a 75kWh pack at ~.2kWh/mile should manage ~370 miles.It would have to average below 202 Wh per mile over the entire 5-Cycle test to get just 300 miles. If you use the magic ~194 Wh per mile number, you may see 318 to 320 miles range. A 90 kWh battery pack might allow for about 350 miles range if you can keep below 208 Wh per mile. I believe that in The Real World you must allow for both Range and Performance. If instead of a 280-to-330 Wh per mile efficiency (as some have observed lifetime with a Model S), the Model ☰ can achieve even a 224-to-264 Wh per mile daily operational consumption...? Then I expect a 300 mile range in the Real World would require an 83 kWh to 98 kWh capacity. If they limit it to 194 Wh per mile as an average consumption, I am afraid it would drive like a Camry. Of course, Tesla Motors could simply 'cheat' like Volkswagen did, and just have the car refuse to go over 194 Wh per mile if its systems detect it may be going through the 5-Cycle test... It is all software controlled, after all.
Tesla’s ‘upgradable’ battery may change the way we buy cars
I presume that there is a 10% 'buffer' for anti-bricking, and that EPA testing results also offer an additional 10% penalty. So, 75,000 Wh times 0.90 comes to 67,500 Wh available for use. 67,500 Wh times 0.90 is 60,750 Wh remaining, once you assume as the EPA does that you have 'spilled electrons on the floor' while filling your car in the garage. 60,500 Wh divided by 200 Wh per mile comes to 303.75 miles, which could be rounded up to 304 miles range.Fwiw, a 75kWh pack at ~.2kWh/mile should manage ~370 miles.
I'm not sure about the EPA methodology but it makes sense to include the charging losses when the number is 'electricity used per mile,' but not when calculating range. It would also be interesting to know whether EPA uses the battery nominal capacity or the usable SOC.I presume that there is a 10% 'buffer' for anti-bricking, and that EPA testing results also offer an additional 10% penalty. So, 75,000 Wh times 0.90 comes to 67,500 Wh available for use. 67,500 Wh times 0.90 is 60,750 Wh remaining, once you assume as the EPA does that you have 'spilled electrons on the floor' while filling your car in the garage. 67,500 Wh divided by 200 Wh per mile comes to 303.75 miles, which could be rounded up to 304 miles range.
Almost, not quite. Notice my saying above, "spilled electrons on the floor"...? The EPA does count the charging losses while filling at home. Their calculations are primarily financial in nature. That's why the numbers don't match. The 37 kWh per 100 miles, or 370 Wh per mile driven, is far worse than the observed 280 Wh per mile to 320 Wh per mile that Tesla Model S owners often report. That difference is the charging losses.I'm not sure about the EPA methodology but it makes sense to include the charging losses when the number is 'electricity used per mile,' but not when calculating range. It would also be interesting to know whether EPA uses the battery nominal capacity or the usable SOC.
I'll have to see whether EPA has numbers to reflect each situation. Or maybe the EPA always includes charging losses and does not account for unused SOC. If both are ~ 10% then the final number is fairly accurate, at least for Li-x.
Addendum:
I checked the 90D Mx. From fueleconomy.gov,
MPGe city 90 Highway 94, average 92
Consumption: 37 kWh/100 miles
92 MPGe average = 2.73 miles per kWh
= 36.3 kWh
So within a rounding error, EPA uses the same assumptions for each number. The sticker says 257 miles range. If based on 37 kWh/100 miles, it implies 95 kWh usable.
My GUESS, then for range:
highway consumption
Charging losses
Nominal capacity rating
This isn't just a financial calculation. The electricity drawn from the wall (and thus including charging overhead) is the energy actually used and thus the CO2 and other pollution emitted to charge your car. Including the charging overhead is important because it encourages car makers to design efficient battery chargers. And let's get real... nobody spills a gallon of gas on the ground when they add 10 gallons to their tank at the gas station.In other words, for every 100 kWh you put into the car at home, the EPA assumes you have paid for 115.62 kWh. Their calculations are 'electricity paid for per mile'... not how much is actually USED by the car. This is, in my opinion, rather unfair because no one presumes that anyone is spilling gasoline or diesel fuel on the ground while filling an ICE. They count the capacity IN THE CAR instead.
Going up the line and including such things is unfair if the same thing is not done for petroleum fuels. The way this is set up currently, it is a disadvantage to EVs. If the same is done with petroleum fuels, the advantage to EVs is multiplied instead.This isn't just a financial calculation. The electricity drawn from the wall (and thus including charging overhead) is the energy actually used and thus the CO2 and other pollution emitted to charge your car. Including the charging overhead is important because it encourages car makers to design efficient battery chargers. And let's get real... nobody spills a gallon of gas on the ground when they add 10 gallons to their tank at the gas station.
This link is pretty good, and if I am reading correctly says that charging losses are not considered in range, but insteadAlmost, not quite. Notice my saying above, "spilled electrons on the floor"...? The EPA does count the charging losses while filling at home. Their calculations are primarily financial in nature. That's why the numbers don't match. The 37 kWh per 100 miles, or 370 Wh per mile driven, is far worse than the observed 280 Wh per mile to 320 Wh per mile that Tesla Model S owners often report. That difference is the charging losses.
My problem with the EPA is that they cannot decide what to be when they grow up (money Vs emissions,) and the attempt to appease ignorant Americans who have no idea what a kWh is but have no intention of buying an EV is nonsensical.Going up the line and including such things is unfair if the same thing is not done for petroleum fuels. The way this is set up currently, it is a disadvantage to EVs. If the same is done with petroleum fuels, the advantage to EVs is multiplied instead.
Miles per gallon gasoline equivalent - Wikipedia, the free encyclopedia
