I presume that there is a 10%
'buffer' for anti-bricking, and that EPA testing results also offer an additional 10% penalty. So, 75,000 Wh times 0.90 comes to 67,500 Wh available for use. 67,500 Wh times 0.90 is 60,750 Wh remaining, once you assume as the EPA does that you have
'spilled electrons on the floor' while filling your car in the garage. 60,500 Wh divided by 200 Wh per mile comes to 303.75 miles, which could be rounded up to 304 miles range.
As usual, I could be wrong. The percentage of the
'reserve' in the battery pack may be a bit less. The penalty for either drivetrain losses or induction losses during charging may be more. But I think this comes pretty close to what we have observed so far. In other words, I no longer count the entire expected capacity of a battery pack as being available for use.
By the way, this is also why I argue so vehemently against a 50 kWh, 45 kWh, or 40 kWh version of the Model ☰. Yeah, sure... If you could use every iota of that capacity, and tuned the vehicle to be incredibly efficient, they might achieve a range over 200 miles... 50 kWh would require 250 Wh or less consumption. 45 kWh at under 225 Wh per mile. 40 kWh at below 200 Wh per mile. Maybe. If you tuned the car to have the equivalent Performance profile of a Prius? It would not be too easy though, given what I have witnessed before.
Knowing that Tesla Motors originally expected ranges of 300-to-320 miles
(Model S 85), 230 miles
(Model S 60), and 160 miles
(Model S 40), I'd rather not cut it so close. Because with the EPA's 5-Cycle Range Tests, the results were 265 miles
(88.3% of expected range), 208 miles
(90.4%), and 139 miles
(86.8%) instead. If the EPA just happens to introduce a new range test, just ahead of the Model ☰ release, that is weighted in favor of ICE, Tesla Motors may not officially reach their intended minimum range. That would be bad.
