B Bitslizer Member Jun 16, 2021 264 93 IL Jul 31, 2021 #1 Jul 31, 2021 #1 Is the Tesla inverter capable of reducing generation as the line frequency rise? Or are they purely on/off for generation?
M morph3ous Member May 8, 2021 72 58 California Aug 1, 2021 #2 Aug 1, 2021 #2 My two Tesla inverters are able to modulate their output based on power frequency. Reactions: nwdiver and Bitslizer
B Bitslizer Member Jun 16, 2021 264 93 IL Aug 1, 2021 #3 Aug 1, 2021 #3 morph3ous said: My two Tesla inverters are able to modulate their output based on power frequency. Click to expand... Do you know how high the frequency goes?
M morph3ous Member May 8, 2021 72 58 California Aug 2, 2021 #4 Aug 2, 2021 #4 Bitslizer said: Do you know how high the frequency goes? Click to expand... Mine was going up to 65hz. I had to call Tesla and have them change it to 62.5hz as it was causing problems with my UPS. Reactions: Bitslizer
B Bitslizer Member Jun 16, 2021 264 93 IL Aug 2, 2021 #5 Aug 2, 2021 #5 morph3ous said: Mine was going up to 65hz. I had to call Tesla and have them change it to 62.5hz as it was causing problems with my UPS. Click to expand... So at 62.5 it was still enough to modulate the generation without totally shutting off?
H h2ofun Active Member Aug 11, 2020 4,763 1,380 auburn, ca Aug 2, 2021 #6 Aug 2, 2021 #6 Bitslizer said: So at 62.5 it was still enough to modulate the generation without totally shutting off? Click to expand... Yep, got them to change mine too and works fine Reactions: morph3ous and Bitslizer
nwdiver Well-Known Member Feb 17, 2013 9,410 14,632 United States Aug 2, 2021 #7 Aug 2, 2021 #7 Bitslizer said: Is the Tesla inverter capable of reducing generation as the line frequency rise? Or are they purely on/off for generation? Click to expand... I believe this functionality is required under Rule 21 which is mandatory in CA => all newer (mid-2017) US inverters should have it. Reactions: Bitslizer
