Right. This is exactly the point I was alluding too.If they would do a conversion, then the $900 Ranger fee might be worth it. Just for a firmware update though, I'm not sure. Maybe they'll offer it someday.
With the Tesla adapter, or equivalent, the pilot signal passes through to the car so it will automatically lower its current draw to 30A, yielding the best charging rate...
... your nearest choices are 32A and 24A. 32A will also pop the breaker, and 24A means you get 20% less charging speed....
Here's the problem: most (if not all) public J1772 charging stations have a current limit of 30A, but because you're plugging your mobile connector into a NEMA 14-50, the Roadster thinks it can draw 40A. If you let that happen, you'll pop the charging station's breaker and render it useless until someone comes out and resets it.
The right answer is for Tesla to give us a 30A option on the VDS as this seems to be the defacto standard current for J1772.
Why have discrete options at all ? The current draw should IMHO be settable to any value between 4 and 70A. I hope they do this for the Model S.
I'm not sure that's true. The J1772 chargers appear to have reset-able over current protection (like the old AVCON and the Tesla HPC).
in the UK we were unable to charge a Roadster successfully using the 13A socket on the Charge Station at the Nissan Dealer. This was despite numerous attempts to reset the system inside the building by the site owners.Didn't they say on Transport Evolved that the Nissan J1772 chargers at the dealerships had to be reset by a technician, even if it only tripped off because someone hit the stop button?
I think that was a DC fast charger that has a big red emergency stop button (like you'd find on industrial equipment). People that don't know any better (or perhaps misanthropic chavs) press that button and the system has to be reset.Didn't they say on Transport Evolved that the Nissan J1772 chargers at the dealerships had to be reset by a technician, even if it only tripped off because someone hit the stop button?
and it's crazy that this is all for a car that can only charge at 16A...I love that Nissan has an electric car, but am getting concerned that it's leading towards new public chargers only supplying 30 amps.
A lock slot could have been included on one of the plugs, then all you would need is one of these:
View attachment 1741 View attachment 1742
Come to think of it, there's an idea in here....an insulated clamp around the cable part and a steel cable with eyelets that can be padlocked through the spoke of the rear wheel:
View attachment 1743 View attachment 1744
Should be easy enough to make with low cost bits from the local hardware store. I know it could be defeated by someone wandering the streets with 6lb bolt-cutters...but seriously folks?
Thanks. And the Tesla adapter would let me use the full 70amps that supposedly are still available at the Rabobank HPCs along 101 that were converted to J1772 earlier this year.
This is not true as they converted with the 30 amp. J1772 connectors, thus the limit to the amperage.
I would sure like to know the actual state of these, as I would like to do a CA coast run some time in August.
