Yeah, I remembered you had posted this in another thread. Any idea how those outliers are performing now with more miles on the odo? I'd love to know if they are still reporting close to their rated capacities.
But are the numbers from wk057 just copied nominal readouts from the car? Or is it nominal+brick he defines as "total capacity numbers"?
You seem to be failing to understand that Dennis is seeing different numbers on some cars.And the total number, including buffer, were ~81.5 kWh for the "85 kWh" battery and ~85.8 kWh for the "90 kWh" battery. Assuming wk057 is correct of course.
This is what I have read from a new 85D and 90D via canbus and also confirmed in the Diagnostic menu.
I have only seen 79 on one 85. Most of 85 Dual motor are 77-78 kWh + 4 kwh brick. (I and a friend have data from 15-20 different Model S)
The older 85 rwd have a few kWh less.
So best case.
85 is 79 kWh usable + 4 brick = 83 kWh
90 is 85 kWh usable + 4 brick = 89 kWh.
In post #7 he states the opposite.
He is asked if the nominal full pack number is total battery size or useable size. wk057 answers that nominal full pack number is usable and does not include brick.
Maybe wk057s readout is from a sub par pack, abused/worn pack or somehting? My pack measurement (84,9 nominal) was brand new.
So the highest he's seen an 85 with 79 usable, (which is close to wk's 77.5), + the brick = 83, and the highest 90 he's seen is 85 usable, + the brick = 89. So both his numbers and wk's could be valid for those specific vehicles.
So best case.
85D
90D
1st post he shows picture of nominal pack size. wk057 adds brick to that number.
Then again in post 7 he repeats the claim that nominal does not equal total pack size. Brick is added to nominal value.
As English isn't my native language, and the 84,9 + brick pack is my own car, I could misunderstand posts and be biased at the same time Appreciate my claims being challenged as it made me study wk057 posts more closely.
On one hand I prefer knowing the exact amount of usable energy. On the other hand, if focus is on useable energy the result could be that manufactures reduce buffers/brick protection to boost numbers.
I'm fine as long as it applies to the whole industry, since the current convention is the total number.A key question from my perspective is should the market (and then, legislation) require that a stated pack capacity in kWh should be usable for the consumer, and should he/she should be allowed to determine how many miles to turn that into? I think yes. If the kWh are not there, as in coming out of the cable leaving the battery, one should be allowed to return the product as defective.
As in the ICE industry, such key performance indicators should be available on an OBD plug.
The ICE industry has gone down the path of promising performance and range a normal customer could never reach with that product. And has cheated in many other ways.
EV makers once promised they would be different. We should hold them to it.
But we know you will be back, thin skin and all. Just like when you said you would never buy another Tesla product and then did. If only you were a man of your word.
