apparent Model 3 comes with a 16A adapter - but UMC is capable of 32A - does that mean I would need to purchase a 32A Commando adapter if I got a 32A Commando socket installed ?
There was a recent thread which may answer that: Here's how to charge with 32A commando in UK
Stupid question - but no Earth Rod needed for Commando ?
Thanks @arg - interesting. Although taken from Pod Point's pdf, it seems to suggest they think they're complying and Exception (iii) provides the weight behind their claim;
Do you know when approval might be given ?
Brilliant, it does, RCD Type B not needed due to loophole.
Needed in the same circumstances as for a fixed chargepoint at that location (ie. outdoors and house earth is PME), if it's a socket for EV charging.
You could cheat and pretend that it's just for your lawnmower...
Thanks again @arg - can I read that also as "indoor" commando negates need for earth rod ?
On another thread, a poster posted this video about Zappi 2 which apparently doesn't need Earth rod;
Is this correct? Or somewhat correct which reduces the risk to an acceptable level that make earth rod redundant? Or just marketing spiel?
I have to admit I'm baffled by the science, I read the threads and try to absorb but my brain is frying! So despite my attempts, I will probably have to accept the "simple" answer that if it meets the regulations then it's a "pass", but I'm still happy to learn from all the replies from the very helpful posters on here.
