@SocalMS, it's not just about how fast you drive, it as about how heavy you are on acceleration and deceleration. Are you pushing the brake pedal to slow down regularly or do you just ease off on the accelerator and let regenerative braking handle more of the deceleration? Same goes for acceleration -- do you floor it or do you push it in a bit and accelerate at a reasonable rate (hint -- if most of the time when you accelerate from a stop at a light and everyone who was next to you is soon in your rear view mirror, you are generally accelerating aggressively. That doesn't mean you don't stomp on the pedal when you need to (or stomp on the brakes when something unexpected occurs and you have to) but it does mean that is not the norm. My daily commute is a mixture of interstate and 2 lane highway driving (along with some suburban streets/neighborhoods/stop signs. On the highway (when traffic doesn't slow things down), my general speed is 65-70 mph (which I wouldn't consider "driving slow and easy" or "driving like a Prius" -- it's what I consider responsible driving keeping pace with the majority of traffic. The result -- I average anywhere between 265 and 295 wh/mile and my "estimated range" is almost always greater than my "rated range" (albeit by only 1 or 2 percent.
It sounds like you drive aggressively compared to the average driver and are concerned that you aren't getting rated range because the ratings are inaccurate. Guess what? If you owned a Porsche, BMW M-series or a Corvette (or a Camry or Accord) you also wouldn't be getting "rated range" as measured in MPG. The only difference is it wouldn't be obvious to you unless you are anal person like I was who closely tracked MPG based on miles between fill-ups and amount of gas added to the car....you'd only see your gas gauge get near "E" (or whatever level you use) and know it was time to add gas...
** No. Use Regen alot..
** Very much easy on the acceleration - I drive it like a normal car.
** This could be true. I don't consciously drive FASTER or SLOWER. I just drive...
** I've been averagaging 310 WH/Mile
** You're probably right.
** I don't... I just assume that I'll lose up to 20% in range... problem solved.
