Tesla S 2019 Air suspension is not available
Fabricpath
14
4
US
Hi,
I am facing a problem were my Tesla S is stuck in very low setting and doesn't lift up. the damage is under carriage, the car run just fine. I tested the compressor and it did work when I gave it direct power from the battery. Bought the air suspension valve block and replace it thinking it was the issue but that didn't help. I get an alarm on the screen says ( TAS_a218 Air Suspension adjustment not available).
Hopefully someone had encountered this issue .
2101Guy
1,427
1,232
thats still under warranty. Take it to the nearest SC.
Unless thats a salvage yard..and you brought a salvaged Tesla. Then...you may find yourself facing some challenges...to include zero ability to supercharge
Reactions: rickyjb
Fabricpath
14
4
US
yeah unfortunately bought it before researching how Tesla treat the Salvage. So now I am on the mission to recover it... not easy.
kkillebrew
Banned
Jun 23, 2019
401
124
austin, tx
These are often not too difficult to repair in ICE cars if you gan get to it all, usually an air line, leaky strut, or bad compressor. Not sure about Tesla - probably not as easy.
k0s0vo
5
-1
UK
I do have the same issue with my Model S, same salvage, but proud, saved myself over 40k. Still supercharges for free and as long as I keep it out of a service centre, should still do.
So, I did the same with replacing the compressor and valve block, also replaced the air suspension module but same error "suspension adjustment unavailable".
Compressor works fine if hooked to 12v, also managed to lift the car up. If you put 12v on the valve block pins...I can give you the combinations if you need. I removed the air lines from the block and noted which + - combinations opens which line...so I lifted it to lets say normal height. Trouble is that headlights get info from suspension as well (so I heard)
Going back to the root of the problem, seems like its just a software issue, since airbags deployed its a crash log somewhere and needs to be deleted. Many guys do reset the airbag modules, but couldn't find anyone who can reset the suspension log. It was a guy but was asking for $800 and was something fishy, like me to buy a linux laptop and he would connect from US to my car in UK to reset something....didn't like it. So still looking
Another guy said that he just asked the tech at Tesla to reset it, and only took minutes...but Id rather stay away. Its not about the free supercharging, bought the car cheap enough, but they will disable the autopilot as well.
T-can pro its a diagnostic module for Tesla
t can,tcan, t can, tesla tool, tesla scaner, tesla diagnostic tool, tesla programming tool, tesla airbag crash data reset, tesla add key, key programming for tesla
EAS-TAS – Tesla Airsuspension System (read and decode fault codes,erase stored fault codes,exit service mode ) - supported until 06.2016
So, that's all I know, and Im stuck
Let me know if you find something else
  • Disagree
Reactions: pts260
mrfixit
18
7
east setauket new york
i too have air suspension problem and yes salvage i jumped out air compressor with 12volts to compressor ran for 2 secs than jumper wires where getting hot, so i know compressor is bad and may have damaged air compressor control module,all tesla authorized body shops have toolbox there is a shop nearby that i may take there in case any crash logs in memory let you guys know
Reactions: Fabricpath
markwfin
12
6
UK
Hi All
I have the same issue i purchased a 2018 Mod S 1380 miles damaged sub frame front, replaced sub and fitted new pump and V block but have the three pin plug that goes in the end of the pump to replace i know the center pin is Ground and the other two are exhaust and boost but i dont know which color wire goes to the other pins.
If any of you have the pin outs and colors for the pump please let me know.
I have decided to but the T-Can Tool as its going to save me money going to get the list of errors i have re set, i live in Ireland.
Anyone facing same issues get back in touch
Thanks
Keep safe
Mark
markwfin
12
6
UK
hi
I am in Ireland doing the same thing, i am going to buy the T-Can tool its only £290.00 plus license here and that £700, so not a bad deal.
If you get the SRS data cleared that costs 125, then get Tesla to claer all the DTC codes there is another 3-4 hrs.
The tesla parts online are very reasonably priced i have stopped buying used parts now the new ones are cheaper.
How you getting on with yours?
All the best
Mark
mrfixit
18
7
hi
All the best
Mark
markwfin does t-can work i was also thinking to buy it for my shop
k0s0vo
5
-1
UK
My compressor works fine, even replaced it with one from ebay, but that one was bad...really noisy and not building up pressure.
But same error.
Also when replaced the air suspension module the whole dashboard lit like a Christmas tree and new bunch of errors, like "car can not start", "software needs upgrading", and air suspension adjustment unavailable.
So unplugged the module, placed the old one and all warnings gone, except the initial adjustment unavailable.
Still stuck.
