SageBrush
REJECT Fascism
Why not both? One can reduce both loss in wire and wire size.
You still have to size for ampacity
Yessa butta: The whole point of the exercise is to go to a smaller size wire and so use less copper.
Yah I’m saying at this rate when combined with an upcoming recession the prices will keep lowering throughout the year. Do I really have to spell that out?Some translation of the mexican gigafactory announcements:
60k GBP for a Model Y sounds like more than 15% margins to me...
But anyway, from the thread:
Model Y Long Range price in France
• 64,990€ before 12 January 2023
• 53,990€ after 12 January 2023
• 50,750€ now
I guess Tesla adjusted the prices to match their growing production with demand. Still think margins are really good at these prices, they probably cost the same as Model 3 to produce. Competition will not be happy with this. Might take a while for consumers to figure out how much they save by buying a Tesla instead of anything else, but eventually they will...
Yeah, continued lowering of costs and price. Tesla will keep a healthy margin.Yah I’m saying at this rate when combined with an upcoming recession the prices will keep lowering throughout the year. Do I really have to spell that out?
The EU pricing now is roughly the same as US pricing. Margins are fantastic. This is nothing to be worried about.Some translation of the mexican gigafactory announcements:
• 50,750€ now
Tesla estimates that $125 - $150B of remaining CapEx is required to get to 20M veh/yr and 1 TWh of scale. Why isn’t this getting more attention?
My first thought was, do the structural battery with a big casting too, for the top and sides, so all locations that might need to be precise would be so between the casting and CNC finishing, with the bottom being stamped and glued/bolted on. Then similarly horizontal members that connect the front and back across the roof line. Give them all very precise alignment holes (made more precise with CNC touch up after sprue removal), affix a few bolts to hold it together, and let the robots weld that structure, then slap on the exterior panels that are normally welded on and if necessary weld them too.Gen 3:
No paint suggests plastic outer panels or pressed stainless steel (thinner and less hard than CT).
Assuming stainless steel, the unboxed process would most likely need the main 3 sections to be welded to one another and then to to outer panels. Is this realistic given that seats are installed etc.?
Visual illustration of the idea ...My first thought was, do the structural battery with a big casting too, for the top and sides, so all locations that might need to be precise would be so between the casting and CNC finishing, with the bottom being stamped and glued/bolted on. Then similarly horizontal members that connect the front and back across the roof line. Give them all very precise alignment holes (made more precise with CNC touch up after sprue removal), affix a few bolts to hold it together, and let the robots weld that structure, then slap on the exterior panels that are normally welded on and if necessary weld them too.
But then it occurred to me, as long as the front and rear are positioned perfectly, and then everything else accordingly aligned perfectly, we don't actually need those things aligning them to be welded into every car. Why not instead have a jig that the front and rear are bolted to, and you can align the other structure and body panels to and weld things, weld up those things, then remove that jig from the car, leaving space for the structural pack to come in later?
It would need to have a way to shrink and be removed, but you can sort of already see how that could work if you just think of an inside out Giga Press, or a nested Giga Press.
I would need to read this more carefully but are you talking about welding the structure together? You then mention a Gigapress that makes castings?Visual illustration of the idea ...
Not following you. I'm not suggesting a rail spur through a Boring Company tunnel, I'm suggesting transport through such a tunnel to a railroad track. The tunnel need be big enough only for a car and its packaging. I'm imagining cars on single vehicle wheeled pallets or something similar, with the cars delivered in such a way that they can pack themselves onto rail cars. If any humans are required outside of checking a box on some paperwork for the railroad, they're doing it wrong.
Not that I know anything about it, but I'm sure the Tesla logistics guys can figure out something much better than loading cars up and moving them around using trucks the way their factories do it now.
The tunnel can be as long as needed, and I can't think of any fundamental reason it can't go under mountains. Of course there probably have to be two tunnels, as the traffic probably needs to be two way. And they'd likely need multiple converging tunnels as the cars will probably originate from more than one place.
There's a new SuC just opened in Brussels, quite likely that's v4 too, I'll pass by and checkDon’t know what to make of this but I’ll throw it out here: apparently a new Supercharger station in the Netherlands has the new V4 stalls:
Height is about right at 1.90 meters. Station has 16 stalls and is located in Harderwijk NL.
Yeah, based on the casting machines in that it would have large assemblies sliding on those linear motion rails, but instead of casting, you use it to hold things together in a precise manner to do the welding (the welding bots would come in from the sides or top or bottom or whatever, no depicted). My previous post has a more in depth description of the idea.I would need to read this more carefully but are you talking about welding the structure together? You then mention a Gigapress that makes castings?
Indeed, and wire sizing is based either on self heating (typical ampacity) or voltage drop (which is also a power loss).You still have to size for ampacity
Unless they explicitly referenced the current motors as SRPM and the new rare earth free ones as PM (which I don't remember to be the case), it's most likely just a simplification for presentations sake.Perhaps it was just poor phrasing during the call, but that's generally not what one understands when they hear "permanent magnet motor", especially as switched-reluctance motors aren't nearly as common.
Interestingly, the label Tesla uses refers to the motors as SWRPM (switched reluctance permanent magnet motors). So the new acronym would ostensibly be SWR?
FWIW, Italian prices have declined just enough to be able to receive incentives. I expect solid sales from Italy, as February is already indicating.The EU pricing now is roughly the same as US pricing. Margins are fantastic. This is nothing to be worried about.
Just yesterday Troy was not raising his quarterly unit estimates despite China producing more than he expected in Feb - because he said Tesla didn’t have enough demand to buy the increased supply.
Today Tesla lowers pricing to increase demand to meet the increased supply out of China - presumably Troy should now raise his quarterly unit estimates.
Health care cost are probably 10 times less in Mexico.Wages in one GM plant in Mexico (representative?) are ~10%-12% of Midwest US levels.
New union at GM Mexico plant could benefit US autoworkers
Workers at GM's pickup plant in Mexico voted for a new union. It will be good news for U.S. autoworkers. But could it impact future pickup prices?www.freep.com
Inventory trends suggest more EU discounts are coming.The EU pricing now is roughly the same as US pricing. Margins are fantastic. This is nothing to be worried about.
